changing speakers
LukePitt
I had quick look at the rear speakers but at first glance it looks like u might need to take the whole plastic surround off! Thinking about seeing if halfords can fit some. Unless any forum members are near Bristol and want some cash. Also my Bose sub doesn't work either!
It's easy mate, the two rear side panels pull off and then so does the whole piece covering the speakers. You'll need to take the two storage boxes out which is simple enough, just put your hand in palm facing upwards, lift and pull out. Its a bit awkward overall and I managed to cut my hands quite a lot but that's just me! You'll then need to snip the old speaker connector off and wire your new ones in. Took me about an hour or so. If you need any further help, let me know and I'll try to explain the best I can :)
Thanks kylefly mate, doesn't sound too bad. I'll have a look later on. U might see a post with a few f's in it later if it doesn't go to plan! I couldn't find any guides On it earlier but I'l. Have another look if I **** anything up! My Bose sub doesn't work at all so might look at that aswell!
