Zed revs dropping and almost or fully cutting out
Flex
Had this a couple of times now after it's been running for a while and say go for petrol, will start her up and fires no problem then revs will drop way low and almost if not will cut out.
No engine man lights coming on at all at the moment.
Bit damp today, possible factor?
Any thoughts?
Don't think so mate. Depending what system u have it sometimes shows pending codes. I don't think it will show a eml for the maf playing up either.
Is there anybody close that u could borrow a sensor from to test it out?
I had a similar problem where the revs dropped and it stalled a few times when I needed to restart the car after it had been on recently, so when filling up with petrol.
I had the throttle body cleaned when the plenum spacer was installed and its not happened since. I seem to remember reading a thread at the time suggesting it was throttle body related which led me to getting mine cleaned.
As suggested, try the throttle body reset, maybe it needs a clean. You can also try cleaning the MAF.
If your still having problems in a couple of weeks, or don't want to try the above yourself, your welcome to pop over and we'll have a look together. I think I've got a spare MAF you can try if need be. :)
  • 3 weeks later...
Cheers Sam, I appreciate that! :thumbs:
