JJ350Z Posted September 5, 2013 Share Posted September 5, 2013 Hi As a new member I wondered if any-one could help me with an issue with the standard Nissan stereo in my soon to be purchased 350Z. Some of the buttons have stopped working on the head unit, ie the pre selector numbers 1-6, and the cd skip track button. I can select preselected stations from the steering wheel ok and CD ok its just on the head unit. Can anyone help? Thanks Quote Link to comment Share on other sites More sharing options...
buster Posted September 5, 2013 Share Posted September 5, 2013 imo the best option is to remove it and bin it. .....and then replace with a aftermarket item.I am sure if you use the search button it will help you some what. with a new unit and the correct loom adaptors you ll be able to retain the steering wheel controls as well. Quote Link to comment Share on other sites More sharing options...
JJ350Z Posted September 5, 2013 Author Share Posted September 5, 2013 That's a shame I was kinda keen to keep it Quote Link to comment Share on other sites More sharing options...
The Bounty Bar Kid Posted September 5, 2013 Share Posted September 5, 2013 Can't the garage sort it out for you before you buy? Quote Link to comment Share on other sites More sharing options...
M13KYF Posted September 5, 2013 Share Posted September 5, 2013 why not go back to tradelink seeing as you have only just bought it from them and get them to sort it Quote Link to comment Share on other sites More sharing options...
buster Posted September 5, 2013 Share Posted September 5, 2013 you maybe able to have it repaired....if its the bose unit it is coded to the ecu so not a case of just buying a second hand unit unfortunatly..i replaced mine with an aftermarket unit and kept the o/e just in case i sell up. to be honest the o/e unit is very dated.a good doudle din unit fitted correctly looks and sound alot better. Quote Link to comment Share on other sites More sharing options...
AliveBoy Posted September 5, 2013 Share Posted September 5, 2013 I don't know what it's worth or if it needs to be re-coded or anything, but I have a bose zed headunit at home that you could try as an option? Quote Link to comment Share on other sites More sharing options...
