370z reset window motors after door-card removal
Adrian@TORQEN
WINDOWS NOT WORKING PROPERLY AFTER DOOR CARD FITED BACK?
If the windows do not close automatically or the power window automatic function (closing only) does not operate properly, perform the following procedure to initialize the power window system:
1. Push the ignition switch to the ON position.
2. Close the door.
3. Open the window completely by operating the power window switch.
4. Pull the power window switch and hold it to close the window, and then hold the switch more than 3 seconds after the window is closed completely.
5. Release the power window switch. Operate the window by the automatic function to confirm the initialization is complete.
6. Perform steps 2 through 5 above for other windows.
  • 4 months later...
Note: Your post will require moderator approval before it will be visible.
