anglais49 Posted September 3, 2013 Share Posted September 3, 2013 So you fit a new motor and need to re-set it to make it automatically move and down a bit when you open/close the door... I've re-set it but it only moves down when I open the door. It doesn't go back up when I close it. And it keeps dropping it every time, even if it's already below the seal, so after about six door openings the window is fully open. Also means I have to put it back up with the switch every time someone opens the door. Have I missed something in the re-set procedure? I did hear that used motors can never be fully re-synced with a different car, so it will never go back up. That sounds like a very stupid way to build a car, but would explain it... Quote Link to comment Share on other sites More sharing options...
370Ad Posted September 3, 2013 Share Posted September 3, 2013 Not sure if this will help: ADDITIONAL SERVICE WHEN REMOVING BATTERY NEGATIVE TERMINAL : Special Repair Requirement INFOID:0000000004460995 INITIALIZATION PROCEDURE 1. Disconnect battery negative terminal or power window switch connector. Reconnect it after a minute or more. 2. Door switch is OFF (close). 3. Turn ignition switch ON. 4. Operate power window switch to fully open the window. (This operation is unnecessary if the window is already fully open.) 5. Continue pulling the power window switch AUTO-UP. Even after glass stops at the fully closed position, keep pulling the switch for 3 seconds or more. 6. Initializing procedure is completed. Quote Link to comment Share on other sites More sharing options...
anglais49 Posted September 4, 2013 Author Share Posted September 4, 2013 Cheers, I'll give that a try. So no one has ever heard of a used motor not being able to sync to do the auto up and down? Quote Link to comment Share on other sites More sharing options...
Cozzi Posted September 4, 2013 Share Posted September 4, 2013 http://www.350z-uk.com/topic/23990-window-reset/page__st__20 Little note on this after completing it successfully yesterday, Remove door card. get in the car and shut the door. wind the windows all the way up manually press and hold the reset button on the motor as indicated, wind the window all the way down manually and let go of the button wind the window all the way up again keeping the door shut through the process. The windows should drop 10-20mm when you open the door, and auto up and down functions should be correct. worked both sides for me, keeping the door open didn't work. Quote Link to comment Share on other sites More sharing options...
cs2000 Posted September 4, 2013 Share Posted September 4, 2013 (edited) Its pretty standard procedure in every car ive ever had (modern) and been in. Hold the window switch and let it go down, then keep holding for 5 seconds, then pull the switch, let it close and hold for another 5 seconds. Door does need to be closed though. Ive found the zeds window then stops responding for 5-10 seconds and then it works fine. Edited September 4, 2013 by cs2000 Quote Link to comment Share on other sites More sharing options...
