Toon Chris Posted August 30, 2013 Share Posted August 30, 2013 Since having some work done on my steering fluid cooler my washers have been mysteriously silent and non-functional. I suspect a connection to the motor has been taken off and not put back on. Looking in from the top the washer fluid tube dissapears into the depths of the engine bay. Before I take the entire engine out to find the connector, can anyone tell me where to be looking that might make it a little easier? And do i go in from the top or the bottom? Cheers Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted August 30, 2013 Share Posted August 30, 2013 If it is the front windscreen washers that you are referring to Chris, then the pumps are locacted at the bottom of the washer bottle which you will find behind the front arch liner behind the road wheel. New pumps are in stock if required. Alex. Quote Link to comment Share on other sites More sharing options...
Toon Chris Posted August 30, 2013 Author Share Posted August 30, 2013 Aha! In via the liner. Thanks Alex, i will of course be in touch if it has conked out Quote Link to comment Share on other sites More sharing options...
Ebized Posted August 30, 2013 Share Posted August 30, 2013 Didn't know you had a 370 now....... but blowed if I'm looking back through your 1352 posts to find out when you changed from the 350 Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted August 30, 2013 Share Posted August 30, 2013 Didn't know you had a 370 now....... but blowed if I'm looking back through your 1352 posts to find out when you changed from the 350 He doesn't: Quote Link to comment Share on other sites More sharing options...
