PS13Silvia Posted August 30, 2013 Share Posted August 30, 2013 Hi all, got in the car to come to work this morning, bit of a rush as I was running late. I got off my driveway & 20 yards down the road when I spotted all 3 lights were on. So I stopped, shut the car down & started again, all was fine, didn't think much more of it. However, when I got to work (only 10 miles away) we have to stop at the gate for the carpark passes, did that & pulled away to go & park when I noticed the 3 lights were back on again. Parked at the top as usual & tried pressing the ESP off button, which did nothing so my rev clock looked like this: Have I broken it? Anyone have any ideas what's going on please? Any help or advice appreciated, David, Quote Link to comment Share on other sites More sharing options...
Ebized Posted August 30, 2013 Share Posted August 30, 2013 Check the brake fluid level - make sure it is up to the full mark. This 'fault' has been a fairly common issue with the 350's so I'm guessing the 370 has it in its genes.... Quote Link to comment Share on other sites More sharing options...
PS13Silvia Posted August 30, 2013 Author Share Posted August 30, 2013 Thank you!! I'll check that ASAP. I'm used to older cars with no driver aids so pretty useless when it comes to things like this, saw the lights come on and I just sat there like a retarded monkey scratching my head Quote Link to comment Share on other sites More sharing options...
PS13Silvia Posted August 30, 2013 Author Share Posted August 30, 2013 Just nipped out & checked, car is parked on a hill though (facing downwards because I reversed in) and it's just touching max, if it was on a flat would be slightly below the marker. I've got plenty of fluids at home so will top it up & see what happens. Best keep a close eye on this over the next few weeks. Are these cars really this sensitive? Quote Link to comment Share on other sites More sharing options...
Gudzy Posted August 30, 2013 Share Posted August 30, 2013 (edited) The 350s can show errors if the brake fluid isn't right at the maximum. I had a problem with the brake switch in my 350 which wasn't turning the brake lights on which brought up the same lights, so you could also check those are all lighting up as they should be. When pressing the brakes on with a small amount of force the warning lights would come up on the dash but the brake lights were all just coming on very faintly. Edited August 30, 2013 by Gudzy 1 Quote Link to comment Share on other sites More sharing options...
PS13Silvia Posted August 30, 2013 Author Share Posted August 30, 2013 I walked into town at lunch & got a bottle of brake fluid, moved the car onto a flat level surface and it needed the smallest dribble known to man. Drove home watching the clocks like a hawk and all was fine, right up until I reversed onto my driveway when they lit back up again! I'm being boring & staying in tonight, so will wait till its darker & test the brake lights (tucked right up to the garage door on purpose for this) And a friend is bringing his OBD reader thing in case theres any codes, engine light never came on so I'm not sure it's thrown an error code at all. Bit more research needed for this one on my part... Quote Link to comment Share on other sites More sharing options...
Sharpen Posted September 2, 2013 Share Posted September 2, 2013 Maybe worth checking your abs connections at each wheel after doing all the work on the springs etc. Quote Link to comment Share on other sites More sharing options...
