parello9 Posted August 24, 2013 Share Posted August 24, 2013 Basically this bonnet has 2 yellow stripes down it Do you think there would be any way to take them off? Apparently i cant sand it as its very good paint? Quote Link to comment Share on other sites More sharing options...
Jetpilot Posted August 24, 2013 Share Posted August 24, 2013 You can buy a special paint stripper for fiberglass, so being carbon is the same construction, gel coat, you could use that. There is no reason you could not sand it off however if you were very careful with some very fine wet and dry. Quote Link to comment Share on other sites More sharing options...
cs2000 Posted August 24, 2013 Share Posted August 24, 2013 Oh dear that's bad... Well, whoiever told you yolu cant sand it clearly doesn't understand sandpaper. BulletMagnet refurbed his CF bonnet by wet & drying the entire thing then lacquering it as required. I'm sure you are aware sandpaper is friction material and it will remove any kind of paint no matter what it is, I highly doubt its a proper job whereby the bonnet was painted then relacqured so will probably be a few hrs work and of course you will need to refurb the bonnet afterwards id suspect. Quote Link to comment Share on other sites More sharing options...
rtbiscuit Posted August 24, 2013 Share Posted August 24, 2013 is there a paint line, if you rub your nail across it can you feel where the 2 parts meet? Quote Link to comment Share on other sites More sharing options...
