[SOLD] VENAIR SPORT red full coolant kit hoses for 350z DE
Adrian@TORQEN
Includes an extra piece of hose for radiator.
Specs:
http://cougarstore.c...88e96348c96e615
The Venair coolant hose kit replaces the original factory hose set and is an extremely popular modification to make when improving the hoses in your engine bay. A Venair coolant hose kit will transform the looks of your engine bay and is offered in many different colours such as red, blue, black and yellow. Compared to their rubber counterparts, a silicone hose kit will also improve cooling performance as they do not perish over time or expand under pressure during performance driving which creates a more smooth flow.
1. All Venair hose kits are available in many different colours. The usual stock held colours available are red, blue, yellow and black. Other colours are available on request and special order and in most cases will arrive to your door within 4 weeks of order.
2. Unlike cheaper kits on the market, when required a Venair hose will actually have an internal metal coil moulded into the silicone for extra rigidity. This is especially apparent on boost piping etc where a large pressure on boost can inflate a rubber pipe reducing power and consistency. All Venair kits are reinforced with fabric which means all hoses will not flex under pressure.
3. Motorsport quality silicone hoses. Venair is a leading brand in silicone hose technology and are used by many professional level motorsport teams such as Renault Sport and Seat Motorsport. Inferior brand silicone hoses will not be able to withstand the harsh conditions of race use without failing.
4. Unlike inferior hose kits, Venair do not pad out their silicone hoses for strength with fillers. This can be very damaging when kits break under stress. Venair only use the finest automotive silicone which gives suitable strength for all road conditions and motorsport use.
5. All Venair hoses are designed to directly replace their OEM counterparts and include any inserts required for use. Breathers, positioning for dump valves etc (on turbo applications) are all pre moulded as one unit on a Venair silicone hose. Many cheaper kits will not have these available which will render the part useless.
Edited by octet
