mickat350z Posted August 20, 2013 Share Posted August 20, 2013 Hi Guys , new member , had my 350z 3 yrs , noticed a distinct change of tone from the exhaust , checked it out to find out the back box joint to the pipe coming under the axle has broken at the diamond shaped jointing bracket , obviously rusty but the pipe itself is good either side and was wondering does anyone know if you can get a sleeve or new bracket pieces to weld on and bolt back together ??? Quote Link to comment Share on other sites More sharing options...
MITZ@CougarStore Posted August 20, 2013 Share Posted August 20, 2013 You can weld a sleeve in place or you can contact us and we'll team you up with a new replacement... The Cobra Sport system we do makes an excellent replacement for the OEM one - http://cougarstore.co.uk/index.php?main_page=index&cPath=1_10 Quote Link to comment Share on other sites More sharing options...
mickat350z Posted August 20, 2013 Author Share Posted August 20, 2013 Hi guys , is that with the diamond shaped plates on or a sleeve slipped into both pipes and welded .thanks for the quick reply , Mick Quote Link to comment Share on other sites More sharing options...
MITZ@CougarStore Posted August 20, 2013 Share Posted August 20, 2013 Mick, you'll need to cut the fitting away, and then weld a sleeve into place, as a short term fix it works well, some last and some don't... Quote Link to comment Share on other sites More sharing options...
mickat350z Posted August 20, 2013 Author Share Posted August 20, 2013 Ok guys thanks for your help Quote Link to comment Share on other sites More sharing options...
