O2 Spacers L Shaped
Deklan
Angled Lambda Sensor Boss Nut in Mild Steel
Sorry for the pics didn't have a PEN!!!
Threaded Lambda Boss angled so it’s perfect for tight awkward spaces.
Specification - M18 x 1.5mm
Particularly useful after decatting your car.
Universal fitting, and can fit majority of cars with a screw fitting, however please check your exhaust to be certain.
These are available in mild steel or T304 stainless steel (highest grade stainless you can get - see our other listing)
Simply select your preferred material (obviously stainless steel has much higher resistance to heat and corrosion.)
If you have fitted a header/test pipe/high flow cat it’s likely that your vehicle has gone in limp mode. This is usually due to the fact that the sensor is reading the added exhaust flow and throwing up a fault. In limp mode your vehicle will be rev limited, you will use more fuel and can only drive very slowly.
This spacer will solve this problem, It spaces your O2 sensor away from the added exhaust gases/heat and allows the sensor to read correctly so no faults are sent to the ECU
Also if you have added a fuel cell the ECU could be telling the injectors to inject more fuel due to the extra O2 being read. This will mean you will not save any fuel by adding the HHO fuel cell. Adding our spacer will solve this problem.
Very simple to install, no welding, cutting, drilling etc needed.
Looking for £20 Posted
They were on my car for a week
