Benen Tow Hooks
HaydnH
'Scuse my ignorance if I'm wrong, but are these the ones you're after?
http://hondaperforma...rod&productId=8
OH FFS, they're out of stock! I bloody hate websites that will let you place and order, take your money and then contact you a week later saying "oh we don't have it"... that should be made illegal!! :rant:
Dislike :(
When do you need it by?
Another front one made to fit the back.
Fabrication work done by Ivor from Vortec Systems Swanley.
That's one wideee be-hind!
Also to note, if you plan on driving in Germany I'd be careful with these tow hooks, I've not had experience myself, but apparently the German police don't like them as if you hit a pedestrian you're going to do a lot more damage with them (not that 1.5 tons of metal won't anyway :wacko: ).
Thats why it's on the back and set so far in it's outer ring is no further out than a landrover tow hook.
There are 3/4 settings. I don't have one on the front yet as we have to fabricate a drop down bracket with a thread on it.
I don't want a stick out one nor a floppy one. Those triangle things may be the way to go:)
These look great but dont count on them staying the same shape when you use them. Most are quite flimsy unless towing in a dead straight line.
Make sure the bracket is really heavy duty and as the bolts man enough, It'd bend and cut a hole into your bumper otherwise.
Most likely fakes mate, The Real benen are a lot stronger
