Paddy78 Posted August 19, 2013 Share Posted August 19, 2013 Probably a stupid question and one with a logical answer... I'm pretty sure mine need replacing... or at least the bushes do. Is there any reason to replace the entire arm or will just the bushes be sufficient? The reason I ask is that the uprated polybushes are about £200 and the arms (with stock bushes) are £500! I assume that the arm itself can fail? How would you identify this? Quote Link to comment Share on other sites More sharing options...
ATTAK Z Posted August 19, 2013 Share Posted August 19, 2013 (edited) It's the ball joint in the arm that cannot be replaced, thus necessitating a replacement arm complete. Unfortunately this failure is notoriously difficult to diagnose but is usually associated with a dull thud/rattle when driving slowly over bumpy surfaces (and stops when you left foot brake whilst maintaining the low speed) ETA not a stupid question !!! Edited August 19, 2013 by ATTAK Z Quote Link to comment Share on other sites More sharing options...
Paddy78 Posted August 19, 2013 Author Share Posted August 19, 2013 Cheers ATTAK, that make sense. I'll probably just replace both arms and do the uprated bushes to be on the safe side... Shame it's so damn expensive for some bits of rubber and metal! Quote Link to comment Share on other sites More sharing options...
ATTAK Z Posted August 19, 2013 Share Posted August 19, 2013 Have you tried ZmanAlex ? ... he's a lot cheaper than Nissan Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted August 19, 2013 Share Posted August 19, 2013 Genuine Nissan compression rod bushings are £39.50 each. Genuine Nissan compression rods are circa £225.00 each. The seating cones are £10.00 each and the ball joint nuts are £5.00 each Should also have some Polybushings left in stock as well, if you wish yo go that route. All showing in stock at the moment Paddy. Just drop me a PM if I can help further. Alex. Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted August 19, 2013 Share Posted August 19, 2013 Have you tried ZmanAlex ? ... he's a lot cheaper than Nissan Nice one mate: Thank You. Alex. Quote Link to comment Share on other sites More sharing options...
