Reeco Posted August 18, 2013 Share Posted August 18, 2013 Hi guys, are the rear wishbones (spring mounf) the same just flipped either side? I've basically sheered my toe adjustment bolt and need to cut the bush out, it far cheaper and easier to just buy the whole thing second hand with the bolt and bush in it. Need to order the part ASAP. Thanks Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted August 18, 2013 Share Posted August 18, 2013 Both the same mate. 350z and 370Z preowned lower spring carriers are in stock and good to go same/next day. Alex. Quote Link to comment Share on other sites More sharing options...
Reeco Posted August 18, 2013 Author Share Posted August 18, 2013 cheers alex, i take it the ones you have have got the bush/s and bolts with them too? how much are you charging for one? Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted August 18, 2013 Share Posted August 18, 2013 PM me over the model and year of your car mate. The preowned spring carrier comes complete with inner bush and outer bolt and nut. I think that I may be fresh out of stock of the inner toe adjusting bolt, nut and washer, however I will check this out once I know the car details. Alex. Quote Link to comment Share on other sites More sharing options...
Reeco Posted August 18, 2013 Author Share Posted August 18, 2013 Cheers for the help mate but I've literally found one with everything silly cheap on eBay, thanks again though. Quote Link to comment Share on other sites More sharing options...
