PAJERO Posted August 17, 2013 Share Posted August 17, 2013 Hi, I wish to remove said panel to repaint, Has been scratched by a previous owner , and annoys me every time i get in car, Its a 2007 313, Have seen a write up how to remove on earlier models but is diifferent, Does anyone know how its done without me causing damage and a lump of broken plastic . Thanks Quote Link to comment Share on other sites More sharing options...
Terence Bower Posted August 17, 2013 Share Posted August 17, 2013 Just done mine! Best to ease the panel off from the back first,nearest the door panel card. Everything is plastic clipped so use a little caution,slim flat blade scrapper or similar with card no the levering surface. Are you going to strip of the Soft Touch? It could react to some after market sprays,ended up stripping mine just to get back to the base material.Its the same colour as the Door Card trim. Quote Link to comment Share on other sites More sharing options...
Hooch Posted August 21, 2013 Share Posted August 21, 2013 Not sure if its the same on your year but here's a step by step: http://my350z.com/forum/audio-video-and-electronics-diy/407151-2008-door-panel-removal-front-speaker-install.html Quote Link to comment Share on other sites More sharing options...
