iLott Posted August 14, 2013 Share Posted August 14, 2013 So I get the usual bad gear changes when cold and will be changing the gearbox oil and adding molyslip soon. However I have various other little problems which possibly point to my clutch & flywheel about to give in. 1) it's rather noisy until the pedal is depressed 2) I get clutch judder if I try and pull away perfectly, the whole car shakes! 3) sometimes I have to double clutch when slowing down and coming to a stop to get it into 2nd or 1st 4) clutch pedal doesn't always come all the way up, however this could just be the spring on the pedal 5) again to do with number 4, the pedal has a fair amount of play in it and has to be depressed about an inch before it actually feels like it works the clutch Hope I can get some expert opinions on this from some of you Zed Heads, the car is still under a 6 month warranty from when I bought it so hopefully if it needs to be done I can get it done under that. Thanks guys Dan Quote Link to comment Share on other sites More sharing options...
Keyser Posted August 14, 2013 Share Posted August 14, 2013 (edited) 1) it's rather noisy until the pedal is depressed Bearing on its way out (usually comes with the clutch kit) 2) I get clutch judder if I try and pull away perfectly, the whole car shakes! Assuming standard dual mass fly its starting to go - see DarrenB he destroyed his 3) sometimes I have to double clutch when slowing down and coming to a stop to get it into 2nd or 1st More like gearbox - oil change first - helped a lot of members 4) clutch pedal doesn't always come all the way up, however this could just be the spring on the pedal Usually slave cylinder - replace slave cylinder and add a braided hose - new fluid jobs a good un - he does a kit If your replacing the clutch do this after as it may be a weak spring but I'd expect it to be the cylinder. 5) again to do with number 4, the pedal has a fair amount of play in it and has to be depressed about an inch before it actually feels like it works the clutch As 4 - also a worn clutch plate will increase travel. Edited August 14, 2013 by Keyser Quote Link to comment Share on other sites More sharing options...
spursmaddave Posted August 14, 2013 Share Posted August 14, 2013 ^ what he said but without all the technical stuff Quote Link to comment Share on other sites More sharing options...
iLott Posted August 14, 2013 Author Share Posted August 14, 2013 1) it's rather noisy until the pedal is depressed Bearing on its way out (usually comes with the clutch kit) 2) I get clutch judder if I try and pull away perfectly, the whole car shakes! Assuming standard dual mass fly its starting to go - see DarrenB he destroyed his 3) sometimes I have to double clutch when slowing down and coming to a stop to get it into 2nd or 1st More like gearbox - oil change first - helped a lot of members 4) clutch pedal doesn't always come all the way up, however this could just be the spring on the pedal Usually slave cylinder - replace slave cylinder and add a braided hose - new fluid jobs a good un - he does a kit If your replacing the clutch do this after as it may be a weak spring but I'd expect it to be the cylinder. 5) again to do with number 4, the pedal has a fair amount of play in it and has to be depressed about an inch before it actually feels like it works the clutch As 4 - also a worn clutch plate will increase travel. Serious knowledge thrown at my ass there! Looks like I may be going to see Horsham developments then! Quote Link to comment Share on other sites More sharing options...
Jez @ H-Dev Posted August 14, 2013 Share Posted August 14, 2013 If you'd like us to check it out, let me know. We've got all the parts (flywheels, clutches etc etc) in stock and can fit them or send mail order Quote Link to comment Share on other sites More sharing options...
iLott Posted August 14, 2013 Author Share Posted August 14, 2013 If you'd like us to check it out, let me know. We've got all the parts (flywheels, clutches etc etc) in stock and can fit them or send mail order Thanks Jez, are you open weekends to have a look? See if you can give it a quick check over? and possibly advise me on what to do with the warranty company if anything does need replacing/repairing Dan Quote Link to comment Share on other sites More sharing options...
Jez @ H-Dev Posted August 14, 2013 Share Posted August 14, 2013 (edited) Not usually open on the weekends I'm afraid - will be about on the 31st in the morning though If you'd like us to check it out before then, it'll have to be during the week. Edited August 14, 2013 by Jez Quote Link to comment Share on other sites More sharing options...
iLott Posted August 14, 2013 Author Share Posted August 14, 2013 Okay then how about Friday, I can swing by as I'm off work? Quote Link to comment Share on other sites More sharing options...
4RE Leather Posted August 14, 2013 Share Posted August 14, 2013 My clutch does not have a spring? But it has the fittings where a damper or spring should go! Quote Link to comment Share on other sites More sharing options...
Jez @ H-Dev Posted August 14, 2013 Share Posted August 14, 2013 I'll be about until about 2pm this Friday Quote Link to comment Share on other sites More sharing options...
iLott Posted August 14, 2013 Author Share Posted August 14, 2013 Okay Jez I'll probably see you then! Quote Link to comment Share on other sites More sharing options...
