Wheel compatibility with Eibach Spacers
drfeelgood73
Ok... So just fitted my eibachs.( fitted bolts and retaining nut kit).. 20mm front... 25 mm back..... Perfect for Rays and standard 18" alloys as the centre is recessed to allow for the spacer bolts which are longer than the face .....
Went to add my Antera 19"s..... And they don't have the recess , so I had to grind off 3 threads on each hub stud, which left two threads through the retaining nut holding spacer onto hub.
Just wondered if anybody else had to mod there hub bolts.... And with what wheels....
