z350convert Posted August 13, 2013 Share Posted August 13, 2013 Not the most technical question but here goes... There is a spring loaded switch on the left as you view the engine. Doesn't seem to do anything but it looks like it might be an on/off (door type) switch for a light in the engine bay that doesn't seem to be there (the light, not the engine). Does anyone know what it should do?? Thought I might put a light near the dipstick as I struggle to get that ridiculous bendy thing back in the right place and maybe use the switch already there. Thanks Quote Link to comment Share on other sites More sharing options...
HORNZEE Posted August 13, 2013 Share Posted August 13, 2013 Think it's something to do with the alarm just in case someone try's to pop the bonnet and nick it...... Quote Link to comment Share on other sites More sharing options...
BulletMagnet Posted August 13, 2013 Share Posted August 13, 2013 If you leave the bonnet open or don't close it properly, the "door open" light on the dash stays on Quote Link to comment Share on other sites More sharing options...
z350convert Posted August 14, 2013 Author Share Posted August 14, 2013 Thanks I will check it. I think the door open warning light was not lit with the bonnet up but I will look again. That plunger switch must be there for some reason, just can't see what it is. Thanks Neil Quote Link to comment Share on other sites More sharing options...
stubzie83 Posted August 14, 2013 Share Posted August 14, 2013 Definitely there for the alarm. If you try and lock the car with the bonnet or the boot not shut properly you'll hear a tone from inside the car. I think of you don't unlock and rectify the situation the alarm will go off Quote Link to comment Share on other sites More sharing options...
glrnet Posted August 14, 2013 Share Posted August 14, 2013 Thanks I will check it. I think the door open warning light was not lit with the bonnet up but I will look again. That plunger switch must be there for some reason, just can't see what it is. Thanks Neil It will if you then turn the ignition on which is what I think BM meant. Quote Link to comment Share on other sites More sharing options...
AliveBoy Posted August 14, 2013 Share Posted August 14, 2013 It's for the alarm. I have bonnet pins, so I can open the bonnet without unlocking the car, when I do so the alarm goes off. Quote Link to comment Share on other sites More sharing options...
coldel Posted August 14, 2013 Share Posted August 14, 2013 Actually think that an under bonnet light might be quite a useful mod! Quote Link to comment Share on other sites More sharing options...
z350convert Posted August 14, 2013 Author Share Posted August 14, 2013 This is the bit... http://www.ebay.com/itm/ws/eBayISAPI.dll?ViewItem&item=221244060144&catId=6000&item=221244060144 Have read some other thread where they thought it was an air bag sensor but an alarm is more likely. Anyway i think i shall not mess with it and rig my own switch and lead for an under bonnet lamp. Thanks Neil Quote Link to comment Share on other sites More sharing options...
