RickyZ Posted August 12, 2013 Share Posted August 12, 2013 So I had my car serviced today and unfortunately on the health check they noticed the lower arm bushes have failed. Anyone know if I can buy the bush set or do I need to replace the whole arm? Here's a video to show you http://www.citnow.com/av241230224 Quote Link to comment Share on other sites More sharing options...
M13KYF Posted August 12, 2013 Share Posted August 12, 2013 yes you can. Couple of the traders here sell the bushes or you can get them off ebay Quote Link to comment Share on other sites More sharing options...
RickyZ Posted August 12, 2013 Author Share Posted August 12, 2013 Ah good, ill have to send a few pm's out. Is it just zmanalex and CS that do these? 1 Quote Link to comment Share on other sites More sharing options...
Mikesding Posted August 12, 2013 Share Posted August 12, 2013 liking the video showing you what's wrong 1 Quote Link to comment Share on other sites More sharing options...
RickyZ Posted August 12, 2013 Author Share Posted August 12, 2013 yeah I was quite impressed with that tbh Quote Link to comment Share on other sites More sharing options...
MITZ@CougarStore Posted August 12, 2013 Share Posted August 12, 2013 Ricky, this is what we do - http://cougarstore.co.uk/index.php?main_page=product_info&cPath=1_66&products_id=195 Quote Link to comment Share on other sites More sharing options...
Neilp Posted August 12, 2013 Share Posted August 12, 2013 Cs will sort u superpro bushes and to be honest they're the business with a lifetime warranty! 1 Quote Link to comment Share on other sites More sharing options...
ddcboyle Posted August 12, 2013 Share Posted August 12, 2013 Thats awesome. The fact they show u a video. And ty for sharinf I might go check mine Quote Link to comment Share on other sites More sharing options...
scottyd Posted August 12, 2013 Share Posted August 12, 2013 iv'e got some for sale buddy http://www.350z-uk.com/topic/71803-superpro-front-banana-compression-arm-poly-bush-set/ Quote Link to comment Share on other sites More sharing options...
brillomaster Posted August 13, 2013 Share Posted August 13, 2013 were you getting a rattling noise from the car over uneven roads? currently suffer from rattle myself, everything i've read suggests its the compression arm bushes, but want to be sure before i fork out £200 to replace them! Quote Link to comment Share on other sites More sharing options...
georgerobertfreeman Posted August 13, 2013 Share Posted August 13, 2013 Compression arm bushes are a common fault. I had the knock on uneven ground and replaced the bushes with the super pro kit. However it hasn't cured the problem. After reading the forums it sounds like it could be the ball joint bush on the compression arm. This part isn't available to change on its own so a whole new arm may be needed. Quote Link to comment Share on other sites More sharing options...
brillomaster Posted August 13, 2013 Share Posted August 13, 2013 hmmm, will try and get up on a ramp to see if i can identify whether its the compression arm bush, the ball joint, or maybe even the front lower arm bush Quote Link to comment Share on other sites More sharing options...
georgerobertfreeman Posted August 13, 2013 Share Posted August 13, 2013 hmmm, will try and get up on a ramp to see if i can identify whether its the compression arm bush, the ball joint, or maybe even the front lower arm bush It usually very difficult to establish any sort of wear or movement in the joints / bushes as you can not re create the weight of the car going over a bump on a ramp. Quote Link to comment Share on other sites More sharing options...
RickyZ Posted August 13, 2013 Author Share Posted August 13, 2013 yeah get a knock now and again over speed bumps and potholes Quote Link to comment Share on other sites More sharing options...
370Ad Posted August 13, 2013 Share Posted August 13, 2013 Wow what great customer service with the video! Genuine bushes £28 delivered from the US if the traders can't sort you out Quote Link to comment Share on other sites More sharing options...
flyboy Posted August 13, 2013 Share Posted August 13, 2013 if your bush has fallen out like on the video then you will be eating front tyres check your inner edges. I went through a set in 4k when mine was like that. Quote Link to comment Share on other sites More sharing options...
