craig350z Posted August 9, 2013 Share Posted August 9, 2013 Hello people. Right im just about to get some steel grey rota drifts 9.5 front and 10.5 back et 20. Im lowered 30mm on eibach springs. What size tyres should I get ? And what make ? Also my friend keeps going on at me to get stretched ones as im smoothing the car so what would I need if I wanted to do that ? Thanks, Craig Quote Link to comment Share on other sites More sharing options...
Ekona Posted August 9, 2013 Share Posted August 9, 2013 Might help if you let us know what size wheels they are Quote Link to comment Share on other sites More sharing options...
370Ad Posted August 9, 2013 Share Posted August 9, 2013 I imagine they are 19's so you want 245/35 on the front and 275/35 on the back. OEM size! Quote Link to comment Share on other sites More sharing options...
Dave-350 Posted August 9, 2013 Share Posted August 9, 2013 I imagine they are 19's so you want 245/35 on the front and 275/35 on the back. OEM size! On a 9.5j and 10.5j? I thought the tire sizes you specified were for 9 & 10j? Quote Link to comment Share on other sites More sharing options...
craig350z Posted August 9, 2013 Author Share Posted August 9, 2013 Sorry I knew there was something I forgot Rota Grid 19" 9.5" 5x114mm ET20 Rota Grid 19" 10.5" 5x114mm ET20 Quote Link to comment Share on other sites More sharing options...
Dave-350 Posted August 9, 2013 Share Posted August 9, 2013 Sorry I knew there was something I forgot Rota Grid 19" 9.5" 5x114mm ET20 Rota Grid 19" 10.5" 5x114mm ET20 Sorry I knew there was something I forgot Rota Grid 19" 9.5" 5x114mm ET20 Rota Grid 19" 10.5" 5x114mm ET20 Sorry I knew there was something I forgot Rota Grid 19" 9.5" 5x114mm ET20 Rota Grid 19" 10.5" 5x114mm ET20 What I meant was, that 350ad's response seemed like he was quoting 9 & 10J Tyre sizes, I could be wrong! Quote Link to comment Share on other sites More sharing options...
Sized Posted August 9, 2013 Share Posted August 9, 2013 I imagine they are 19's so you want 245/35 on the front and 275/35 on the back. OEM size! On a 9.5j and 10.5j? I thought the tire sizes you specified were for 9 & 10j? That's what I'm running on 9.5 and 10.5. Slight stretch on the front but it's all good Quote Link to comment Share on other sites More sharing options...
Sized Posted August 9, 2013 Share Posted August 9, 2013 Oh and as for make, Michelin Pilot SS all the way. Not cheap but loads of grip, last well, and look great Quote Link to comment Share on other sites More sharing options...
370Ad Posted August 9, 2013 Share Posted August 9, 2013 I imagine they are 19's so you want 245/35 on the front and 275/35 on the back. OEM size! On a 9.5j and 10.5j? I thought the tire sizes you specified were for 9 & 10j? As sized said there is a slight stretch but nothing too noticeable. If you run anything wider the speedo will be out and I can't imagine anything bigger on the front wheels would do the handling any good! Quote Link to comment Share on other sites More sharing options...
370Ad Posted August 9, 2013 Share Posted August 9, 2013 You can see the slight stretch here: Quote Link to comment Share on other sites More sharing options...
Dave-350 Posted August 9, 2013 Share Posted August 9, 2013 I imagine they are 19's so you want 245/35 on the front and 275/35 on the back. OEM size! On a 9.5j and 10.5j? I thought the tire sizes you specified were for 9 & 10j? As sized said there is a slight stretch but nothing too noticeable. If you run anything wider the speedo will be out and I can't imagine anything bigger on the front wheels would do the handling any good! Ah sorry, I thought you were quoting OEM sizes for the wheels. Would the width put it out, I thought it was the Profile of the tire? Maybe I am just a noob. I will be running 235 35 on my 9js and 255 35 on my 10js very soon, once the hubs are machined! Quote Link to comment Share on other sites More sharing options...
Dave-350 Posted August 9, 2013 Share Posted August 9, 2013 You can see the slight stretch here: What ET? Quote Link to comment Share on other sites More sharing options...
370Ad Posted August 9, 2013 Share Posted August 9, 2013 I imagine they are 19's so you want 245/35 on the front and 275/35 on the back. OEM size! On a 9.5j and 10.5j? I thought the tire sizes you specified were for 9 & 10j? As sized said there is a slight stretch but nothing too noticeable. If you run anything wider the speedo will be out and I can't imagine anything bigger on the front wheels would do the handling any good! Ah sorry, I thought you were quoting OEM sizes for the wheels. Would the width put it out, I thought it was the Profile of the tire? Maybe I am just a noob. I will be running 235 35 on my 9js and 255 35 on my 10js very soon, once the hubs are machined! It's the overall rolling radius that puts it out. The closest to the 18" OEM size on 19's is 245/35 an 275/35, that's less than 0.5% out. If your talking about 19's using the tyres sizes above then the front axle will be 1.95% out and the rear axle 2.5% out. Nothing too major most companies say nothing more than +/- 2.5% out. Quote Link to comment Share on other sites More sharing options...
370Ad Posted August 9, 2013 Share Posted August 9, 2013 You can see the slight stretch here: What ET? ET20 on 9.5J F 10.5J R Quote Link to comment Share on other sites More sharing options...
A9H-RX Posted August 9, 2013 Share Posted August 9, 2013 I'm 9.5J rear 265/35/18 8.5J front 235/40/18 Quote Link to comment Share on other sites More sharing options...
craig350z Posted August 9, 2013 Author Share Posted August 9, 2013 Thanks for your help everyone :-) 1 Quote Link to comment Share on other sites More sharing options...
craig350z Posted August 9, 2013 Author Share Posted August 9, 2013 Is there any good tyres but a little cheaper as im spending quite alot allready on the alloys ? Quote Link to comment Share on other sites More sharing options...
HaydnH Posted August 9, 2013 Share Posted August 9, 2013 Oh and as for make, Michelin Pilot SS all the way. Not cheap but loads of grip, last well, and look great I reckon these look sexier: Quote Link to comment Share on other sites More sharing options...
Sized Posted August 9, 2013 Share Posted August 9, 2013 Yokohamas? Looks sweet Quote Link to comment Share on other sites More sharing options...
HaydnH Posted August 9, 2013 Share Posted August 9, 2013 Yokohamas? Looks sweet Yep, AD08s. 1 Quote Link to comment Share on other sites More sharing options...
craig350z Posted August 9, 2013 Author Share Posted August 9, 2013 Very nice but also very expensive. Any cheaper ones but still good ? Quote Link to comment Share on other sites More sharing options...
Ekona Posted August 9, 2013 Share Posted August 9, 2013 Buy cheaper wheels. They're not the bits keeping you in contact with the road. Quote Link to comment Share on other sites More sharing options...
craig350z Posted August 9, 2013 Author Share Posted August 9, 2013 Well that doesnt help ! Im not asking for budget tyres but there are some tyres which are cheaper than them two suggested but still a good tyre like bridgestone potenza, i think. Any good suggestions instead of comments like that ? Quote Link to comment Share on other sites More sharing options...
Sized Posted August 9, 2013 Share Posted August 9, 2013 I had Bridgestone RE050As on my Rays before I switched wheels and they were pretty good. Kumho Ecstas and Vred Ultracs also get some good reviews although I can't comment from personal experience Quote Link to comment Share on other sites More sharing options...
craig350z Posted August 9, 2013 Author Share Posted August 9, 2013 Thank you sized very helpful. Usefull Info :-) 1 Quote Link to comment Share on other sites More sharing options...
