[SOLD] - Torque Solution Billet Aluminum Transmission Mount for 350
Adrian@TORQEN
Torque Solution Transmission Mount
Applications: 2003-2009 Nissan 350z
Used for less than 1000 miles, as new!
This mount replaces existing OEM transmission mount. The transmission mount is made out of high grade billet aluminum material with urethane material for the bushings. With the addition of this mount you will see and feel an improvement with wheel hop being reduced and better traction. This mount will also aid in chassis stability allowing faster lap times with less transmission slop in the drive line. You will notice much more precise shifting in on/off throttle situations like in Road Racing & Autocross..
-Reduces wheel hop / traction loss
-Improved 60fts / e.t's
-Made out of lightweight 6061-T6 billet aluminum
-Street and track torture tested
-Black anodized / Torque Solution Laser engraved
-75A durometer bushings
-LifeTime Warranty
-Made in USA
Edited by octet
Adrian, what did you think to this mount? Worth fitting? Any increase in noise or vibration? Any negatives at all? What are the benefits? Is the improved gear shift noticeable?
Sorry for all the question but I want it but I'm reading so many mixed reviews about changing them. Some say it's great, some say they remove it 10 minutes later as the noise and vibration is unbearable.
