paulashy Posted August 4, 2013 Share Posted August 4, 2013 In the process of changing my headunit and for some reason the airbag light has come on and is flashing at me. Anyone got any ideas what it might be? Or how to get rid of it? All the plugs are connected and seem to have no damage Cheers Quote Link to comment Share on other sites More sharing options...
Keyser Posted August 4, 2013 Share Posted August 4, 2013 See this thread http://www.350z-uk.com/topic/71150-warning-light/ 2nd post down has reset details Quote Link to comment Share on other sites More sharing options...
ATTAK Z Posted August 4, 2013 Share Posted August 4, 2013 Have you moved the seats recently ? Quote Link to comment Share on other sites More sharing options...
paulashy Posted August 4, 2013 Author Share Posted August 4, 2013 Thanks will read now, nope not moved them only thing I have done is take the head unit out and drive the car. Could the fuse have gone maybe? Quote Link to comment Share on other sites More sharing options...
Easty Posted August 4, 2013 Share Posted August 4, 2013 Go on YouTube and put in "350z airbag light reset" it's brings loads of videos of how to reset it with the ignition key it's really easy and works. . . Quote Link to comment Share on other sites More sharing options...
BACON Posted August 5, 2013 Share Posted August 5, 2013 I've done the reset procedure several times but light comes back on within 10 minutes of me starting my car up again. I've checked the "yellow" connector under the seat and it seems okay.......can I disconnect this connector and reconnect? If so, how do I disconnect the two halves? Please be kind as I'm definitely not technically minded! Quote Link to comment Share on other sites More sharing options...
Keyser Posted August 5, 2013 Share Posted August 5, 2013 Its a clip on connector - press the clip in and pull the plugs apart - if you want to. Have you checked cables on both sides? Passenger side is usual culprit. If the light is coming back on it means the fault is still there. Quote Link to comment Share on other sites More sharing options...
Easty Posted August 5, 2013 Share Posted August 5, 2013 If you can see the yellow connector there is a little gray bit that goes over the top you pull this up then you can disconnect it. . . . . When you reconnect it make sure you push it back down, it then locks it closed!! Just out of interest what was you playing with before the light started? Quote Link to comment Share on other sites More sharing options...
georgerobertfreeman Posted August 5, 2013 Share Posted August 5, 2013 Make sure there is nothing under the seat. I kept resetting my Airbag light and after varying amounts of time it would come back on. Turned out to be a magazine that kept setting it off, but I have also read it can be caused by a bottle rolling around. Quote Link to comment Share on other sites More sharing options...
