[SOLD] - MEISTER R Zeta S coilovers for 350z
Adrian@TORQEN
FOR SALE - MEISTER R Zeta S coilovers used for less than 5000 miles.
Front Coilovers
Top Mount: Aluminum with Rubber Bush
Springs Rate: 10kg/mm
Rear Coilovers
Spring Rate: 8kg/mm
ZETA (ζ) is the symbol for “damping ratioâ€, a measurement describing how oscillations in a system die down after a disturbance. The ability to control oscillations is the most important function of a suspension system. The MeisterR Zeta-S is designed with the concept of precision damping ratio that provides flexible control. Zeta-S is engineered to give the right amount of damping for a sporty drive over all type of surfaces whilst providing quick and easy adjustment to handle circuit use.
Damping Adjustment
32 Levels of damping adjustments (compression and rebound) allows easy and precision control of the damping to cater for your style and road conditions
Aluminium Top-Mount*
Anodised Aluminium top-mount with “harden†rubber bush. The “harden†bush replace the standard OE rubber bush and provide better steering response while absorbing road vibration and noise.
Monotube Dampers
High Pressure gassed monotube dampers with large diameter and short-stroke pistons provides rapid damping response and prolong performance under stress.
Black Chromium Plated Damper Thread
The threaded damper body is plated with a new age “Black Chromiumâ€. This plating have been tested in a salt spray test under ASTM B117 Standard for 120 hours with no sign of corrosion.
Heavy Duty Rubber Boot
Dirt are kept out of the damper cylinder with a heavy duty rubber boot. This will prolong the life and the performance of the dampers.
High Performance Springs
High Grade SAE9254 Steel are coil coiled to the exact springs specification. This process ensure strength and durability. The springs are then powder coated and marked with its specification for easy identification.
Perches and Collar
Light weight anodized aluminum spring perches and locking collar allows precise adjustment of the Springs’ pre-load. Polyamides isolators are included to reduce noise.
Lower Bracket
Light weight anodized aluminum bracket are use to reduce weight and allow independent adjustment of the ride height. High Strength double wall design steel bracket are used with MacPherson Strut Suspension for added strength and durability.
Edited by octet
