creaking rear, any help please ?
M350ZB
Got the car back from the stealer and they have now fixed the problem. It did need the drop link lubricating, so thanks for the advice as they didn't have a clue! I will not be going back there again.
Does anybody know of and can recommend a good independent around Nottingham to work done on the Z?
Cheers
Just out of curiosity how much did you pay for this, im going to get right under mine next week, shoudl hopefully sort it, how much am i putting on, am i drenching it or, and i take it will take time to bed in ?
They charged £32.50 plus VAT which was a bit pricey for the amount of time it took. They did both sides and said you need to carefully remove a rubber cover and then spray some grease in there. If you can raise the car then I don't think its much of a job.
Been under neath it and greased it up as best i can, the rubber bits a quite hard to pull back, is this normal or, and any recomended grease or just standard usual stuff be ok, i see on your pick, thanks by the way for posting it, made things so much clearer, that there obviously new, n blue :teeth: , how much you pay for these,a dn how easy were they to fit, any advantages or ?
