M350ZB Posted May 25, 2007 Share Posted May 25, 2007 Yo all, Got my clicking axle done about 3-4 wks ago now, and everything is perfect on that front, but im still getting my creaking noise every now and then, when i pull on my drive at a slant, it creaks what seems from the left rear, also does it if i half mount a kerb, or a slant on the road, any idea's at all, cause when it does it, its doing my head in. Ten out of Ten, Nissan Southend, fixed my clicking axle, and no more clicks, Woo Hoo ! Looking forward to the summer meets boys! Quote Link to comment Share on other sites More sharing options...
M13KYF Posted May 25, 2007 Share Posted May 25, 2007 is the creek noise inside or out Quote Link to comment Share on other sites More sharing options...
M350ZB Posted May 25, 2007 Author Share Posted May 25, 2007 seems to be on the outside, i think coming from the left rear ! Quote Link to comment Share on other sites More sharing options...
lomoto Posted May 25, 2007 Share Posted May 25, 2007 Creaking rear ...sounds painfull Quote Link to comment Share on other sites More sharing options...
M350ZB Posted May 25, 2007 Author Share Posted May 25, 2007 Its really painfull, lol. Anyone got nay idea's at all, as im at a loose end ! Quote Link to comment Share on other sites More sharing options...
lomoto Posted May 25, 2007 Share Posted May 25, 2007 antiroll bar bush a bit dry perhaps ?? Quote Link to comment Share on other sites More sharing options...
jonathan73 Posted May 25, 2007 Share Posted May 25, 2007 I've read about the Clicking Axle problem and wondered if anyone could describe it a bit better for me.... I sometimes hear (when the passenger window is down) a "tick" sound upon accel / decel. Is this the Clicking Axle problem and do I need to see a Stealer? How bad does it need to be to get fixed? Is it dangerous or just annoying? Quote Link to comment Share on other sites More sharing options...
lomoto Posted May 25, 2007 Share Posted May 25, 2007 I've read about the Clicking Axle problem and wondered if anyone could describe it a bit better for me.... I sometimes hear (when the passenger window is down) a "tick" sound upon accel / decel. Is this the Clicking Axle problem and do I need to see a Stealer? How bad does it need to be to get fixed? Is it dangerous or just annoying? generally you hear this on initial take off, a distinct click / clunk Quote Link to comment Share on other sites More sharing options...
M350ZB Posted May 25, 2007 Author Share Posted May 25, 2007 The clicking axle will cause no damage to the car, jsut an annoyence, i got mine fixed at nissan, southend. There are two ways of getting it fixed the cheaper, being a re-lube, new nuts and bolts, or the more expensive, changing the shafts, so far all is good on mine, just got to find the creaking noise now, the hunt continues .......... Quote Link to comment Share on other sites More sharing options...
Ade McB Posted May 26, 2007 Share Posted May 26, 2007 Strangely enough my car has just started creaking from the rear end as well. Noticed it a couple of times yesterday when I was reversing slowly on a cobbled street. I've not had the clicking axle problem though so it can't be related to anything that the stealers have done. Quote Link to comment Share on other sites More sharing options...
bigphil Posted May 26, 2007 Share Posted May 26, 2007 The creaking at the rear comes from the drop links on the anti roll bar. The rubbers can be eased back and apply some spray grease. Quote Link to comment Share on other sites More sharing options...
Ade McB Posted May 26, 2007 Share Posted May 26, 2007 Cheers Phil. I'll give it a try. Quote Link to comment Share on other sites More sharing options...
M350ZB Posted May 28, 2007 Author Share Posted May 28, 2007 Do you have a drawing of these rubbers to pull back and where everything is, weather been pretty poor all weekend, but hopefull yit will clear for tommorrow and i want to have a look, did this fix yours, or ? Quote Link to comment Share on other sites More sharing options...
AndyC Posted May 29, 2007 Share Posted May 29, 2007 Does it sound like its coming from the rear strut cover? I know Val fixed his with a load of tape - may be worth a look at that first. Quote Link to comment Share on other sites More sharing options...
M350ZB Posted May 29, 2007 Author Share Posted May 29, 2007 im not to sure where it is coming from, but if i pull on to my drive, my drive is a slant it creaks, also if i mount half a kerb with my car it creaks, defo the rear, not to sure, where from though, anyone got any pics, and what did he do exactly ?, i-e, where he put the tape and that, what was loose on his 350z?. Ithink it is coming from the rear left, but hard to tell ! Quote Link to comment Share on other sites More sharing options...
M350ZB Posted May 31, 2007 Author Share Posted May 31, 2007 anyone got any pics or anything relating to this topic, still creaking, did you use WD40 or actaul grease, what type, e.t.c ? Quote Link to comment Share on other sites More sharing options...
stuey Posted June 1, 2007 Share Posted June 1, 2007 dont use wd40....... that will wash the grease out..!! Quote Link to comment Share on other sites More sharing options...
M350ZB Posted June 1, 2007 Author Share Posted June 1, 2007 Whoops, looks like a case of re-greasing up tommorow, any ideas on what grease, or don tthis matter, any diagrams at all please anyone ? Quote Link to comment Share on other sites More sharing options...
bigphil Posted June 1, 2007 Share Posted June 1, 2007 Whoops, looks like a case of re-greasing up tommorow, any ideas on what grease, or don tthis matter, any diagrams at all please anyone ? pic of the sway bar setup, although this is a different bar I have used this pic because it is easy to point you i the right direction. The right hand end of the blue bar shows the connector or drop link, it is this drop link which needs lubricating. If you look carefully you willsee the rubber which needs to be pulled back and then use a staightforward spray grease, mostof thse come with a small straw attachment to make it easier to direct the spray right inside the rubber. Quote Link to comment Share on other sites More sharing options...
M350ZB Posted June 1, 2007 Author Share Posted June 1, 2007 thanks mate, gonna give that a go when i give it a clean tommorow, hopefull y this will cure it, thanks alot, your car looks well clean, have you got any suttle mods or you a major mod man ? Quote Link to comment Share on other sites More sharing options...
M350ZB Posted June 4, 2007 Author Share Posted June 4, 2007 i have tried re-greasin it, by jsut getting under neath the car, i cant really pull it back to get it in there, you got any more tips or pics, ideas ?, still creaking, but slightly better ? Quote Link to comment Share on other sites More sharing options...
bigphil Posted June 5, 2007 Share Posted June 5, 2007 i have tried re-greasin it, by jsut getting under neath the car, i cant really pull it back to get it in there, you got any more tips or pics, ideas ?, still creaking, but slightly better ? you need to lift the car and have the wheels off to get to them properly, you can't really get to the rubbers from just underneath the car, needs to be done from the wheel arch. Quote Link to comment Share on other sites More sharing options...
M350ZB Posted June 5, 2007 Author Share Posted June 5, 2007 Thanks mate, hopefully will have a go next week, and while up ill fit my new chin spoiler, a bigger job than i thought, also want to give my wheels a good old soak, ill let you know ? Quote Link to comment Share on other sites More sharing options...
Pistonzed Posted June 6, 2007 Share Posted June 6, 2007 I had the exact same problem at the weekend. I really bad creaking from the rear when on a hill or parked on the curb. It was so bad that even getting in or out of the car made it happen. The off side rear seamed to drop very far into the wheel arch when parked half on the curb but looked fine when on the flat. I spoke to the nissan dealer and he said don't drive it so I had to get it on the back of an RAC truck from Leeds back home to Nottingham straight in to the stealer who then couldn't find anything wrong with it!!!! I'll give him a call now and tell them what you guys have been saying to see if he can sort the problem. Will keep you posted to see if it works. Quote Link to comment Share on other sites More sharing options...
M350ZB Posted June 6, 2007 Author Share Posted June 6, 2007 mine sits ok on kerbs and that, but problem is very similar, not as bad as it was, you should try the above method ?, i hopefully am next week, anymore pics ? Quote Link to comment Share on other sites More sharing options...
