MickJ Posted May 24, 2007 Share Posted May 24, 2007 The GT4 is the zippiest 350Z Nissan has yet sold in the UK. The award winning 3.5-litre V6 motor gets revised pistons and camshaft as well as electronic exhaust valve timing control. This helps produce another 20PS to give 300P Bit of blurb from the spec, but what does this valve control thingy actually do? Quote Link to comment Share on other sites More sharing options...
Zzzz... Posted May 24, 2007 Share Posted May 24, 2007 It is like a VTEC system on a honda, or VVT on Toyota. After Combustion process in the cylinder the exhaust valve opening will be controlled by an electronic system which monitors engine speed, throttle position, Air flow etc... and decide the optimun valve opening height, and time to remain open, overlap to the inlet valve opening etc... so that at any engine speed, drive condition, you get the optimum exhaust gas discharge and allow more fresh air and fuel into the cylinder, improving the combustion process and getting a few extra horses along the way... that's my theory anyway... Quote Link to comment Share on other sites More sharing options...
Sarnie Posted May 24, 2007 Share Posted May 24, 2007 The GT4 is the zippiest 350Z Nissan has yet sold in the UK. The award winning 3.5-litre V6 motor gets revised pistons and camshaft as well as electronic exhaust valve timing control. This helps produce another 20PS to give 300P Bit of blurb from the spec, but what does this valve control thingy actually do? It just means that as your car is yellow it develops 20 more BHP Quote Link to comment Share on other sites More sharing options...
monkfish Posted May 24, 2007 Share Posted May 24, 2007 The GT4 is the zippiest 350Z Nissan has yet sold in the UK. The award winning 3.5-litre V6 motor gets revised pistons and camshaft as well as electronic exhaust valve timing control. This helps produce another 20PS to give 300P Bit of blurb from the spec, but what does this valve control thingy actually do? It just means that as your car is yellow it develops 20 more BHP As usual, Sarnie provides the scientific answer........... Quote Link to comment Share on other sites More sharing options...
sl114 Posted May 24, 2007 Share Posted May 24, 2007 The GT4 is the zippiest 350Z Nissan has yet sold in the UK. The award winning 3.5-litre V6 motor gets revised pistons and camshaft as well as electronic exhaust valve timing control. This helps produce another 20PS to give 300P Bit of blurb from the spec, but what does this valve control thingy actually do? It just means that as your car is yellow it develops 20 more BHP What about the black ones? Quote Link to comment Share on other sites More sharing options...
jonathan73 Posted May 24, 2007 Share Posted May 24, 2007 They are about 30 bhp more Quote Link to comment Share on other sites More sharing options...
Zzzz... Posted May 24, 2007 Share Posted May 24, 2007 The latest Valve Control system is called VVEL Variable Valve Event Lift or somthing like this ... but essentially a similar system... for the geek inside of you... Will be applied on the G37 just released... I am not sure (can't remeber) if the VQ35HR on 07MY will have VVEL Quote Link to comment Share on other sites More sharing options...
Chesterfield Posted May 24, 2007 Share Posted May 24, 2007 The black ones need to be more powerful in order to shift the extra weight in bolt on parts that the owners put on to try and get half the attention a yellow one does. Quote Link to comment Share on other sites More sharing options...
jonathan73 Posted May 25, 2007 Share Posted May 25, 2007 Just 'cos you didn't have an altercation on your journey over to karting last night doesn't mean you have to start one here True though, the yellow is for sure an in-yer-face colour. Black's the Stealth Bomber. Quote Link to comment Share on other sites More sharing options...
Beavis Posted May 25, 2007 Share Posted May 25, 2007 Just 'cos you didn't have an altercation on your journey over to karting last night doesn't mean you have to start one here True though, the yellow is for sure an in-yer-face colour. Black's the Stealth Bomber. Well mine loks like a wasp this morning because the front is completely black with splattered bugs. I tore up the A50 last night back home. Quote Link to comment Share on other sites More sharing options...
jonathan73 Posted May 25, 2007 Share Posted May 25, 2007 The A50 is a sweet stretch of road, surprisingly Speed Camera Free too Glad you got back safely. Quote Link to comment Share on other sites More sharing options...
M13KYF Posted May 25, 2007 Share Posted May 25, 2007 yes agree, the A50 is almost like a toll road Quote Link to comment Share on other sites More sharing options...
holtehero Posted May 25, 2007 Share Posted May 25, 2007 Until the M6 toll opened i always used the A50 when i went to Manchester as it never had anything on it, still do if its a non business trip Can't believe there are no speed cameras until Stoke Quote Link to comment Share on other sites More sharing options...
