mrchic Posted July 30, 2013 Share Posted July 30, 2013 (edited) Hi I posted a while back about having starting problems which is likely to be the Clutch sensor switch. Anyway of bypassing it permanently, its starting to do it more and more and taking a few minutes of pedal dancing before it starts. Its a bugger to access the switch, but i am waiting for a few days when i don't need the car to have a go. I will PM Zedman for a price on a spare switch, but hoping its just a case of cleaning it. If anyone has removed/cleaned the switch, any tips would be appreciated Thanks Been Looking at this post http://my350z.com/fo...and-adjust.html Edited July 30, 2013 by mrchic Quote Link to comment Share on other sites More sharing options...
karlh Posted July 30, 2013 Share Posted July 30, 2013 Remember that there are two switches activated by the clutch pedal. One switch closes when the pedal is depressed, allowing you to start your car. The other opens when the pedal is depressed to cancel the cruise control. Karl 2005 6MT Quote Link to comment Share on other sites More sharing options...
mrchic Posted July 30, 2013 Author Share Posted July 30, 2013 Remember that there are two switches activated by the clutch pedal. One switch closes when the pedal is depressed, allowing you to start your car. The other opens when the pedal is depressed to cancel the cruise control. Karl 2005 6MT Thanks yes, both tricky to get to, been using a torch and a mirror. The wires are tight to the bodywork, so going to be hard just removing the connector Quote Link to comment Share on other sites More sharing options...
