IDH Posted July 30, 2013 Share Posted July 30, 2013 Hi I have developed a crunch! If I accelerate hard, changing 5th to 6th, I am getting a gear crunch. If I just drive "sensibly" its fine. Anyone heard of anything similar and what may be the solution? Cheers Ian Quote Link to comment Share on other sites More sharing options...
stubzie83 Posted July 30, 2013 Share Posted July 30, 2013 I had this as well at about 42k miles. I ended up getting a reconditioned gearbox put in at abbey motorsport when my clutch was due for a change. Been absolutely fine since Quote Link to comment Share on other sites More sharing options...
spursmaddave Posted July 30, 2013 Share Posted July 30, 2013 I had this at 75k, had a gearbox oil change with molyslip added and was good for close to another 40k mine also made a really bad vibration noise at certain revs in 5th too... Quote Link to comment Share on other sites More sharing options...
ATTAK Z Posted July 30, 2013 Share Posted July 30, 2013 It's quite common - I lived with it without problems Quote Link to comment Share on other sites More sharing options...
Pnthrblkzs Posted July 30, 2013 Share Posted July 30, 2013 It's common i believe and worse when cold. Quote Link to comment Share on other sites More sharing options...
cs2000 Posted July 30, 2013 Share Posted July 30, 2013 (edited) Yep, sadly all to common. I just change from 5-6 slower than usual, wait for the RPM to drop a little. After all, if your hooning it in 5th and heading for 6th you're already doing somewhere 100+ Edited July 30, 2013 by cs2000 Quote Link to comment Share on other sites More sharing options...
IDH Posted July 30, 2013 Author Share Posted July 30, 2013 Thanks guys. I will work on the "all too common" rather than new gearbox! 100+? Me? Never! Planning on selling her on and was worried about it. Ian Quote Link to comment Share on other sites More sharing options...
spursmaddave Posted July 30, 2013 Share Posted July 30, 2013 I must admit i never used 6th until doing 70-80 on the motorway... Definitely get some molyslip added first if that doesn't help then could be something a little more complicated/expensive unfortunately... Quote Link to comment Share on other sites More sharing options...
wackosr Posted July 30, 2013 Share Posted July 30, 2013 Same on mine, just need to wait a split second longer before changing. Not really a problem at lower speeds. After two years of ownership it hasn't got any worse, that I've noticed or caused any issues. Also added some Molyslip on last service a month ago, has helped a little. Quote Link to comment Share on other sites More sharing options...
peteman35 Posted July 30, 2013 Share Posted July 30, 2013 Mines completely dead i have to let the revs drop all the way before changing Quote Link to comment Share on other sites More sharing options...
Deklan Posted August 18, 2013 Share Posted August 18, 2013 Mine did it, Mines a 2006. Turned out to be the synchromesh, result was a rebuild. Grand total 2K from a stealer.... Was meant to be a warrenty job, but they revoked it after the work was done Quote Link to comment Share on other sites More sharing options...
Deklan Posted August 18, 2013 Share Posted August 18, 2013 P.S at the time mine had only done 30,000 miles Quote Link to comment Share on other sites More sharing options...
glrnet Posted August 19, 2013 Share Posted August 19, 2013 Synchro issue on mine at 32k, was repaired under warranty and fine ever since Quote Link to comment Share on other sites More sharing options...
Deklan Posted August 19, 2013 Share Posted August 19, 2013 Lucky you! Wish mine was covered but yer mine has been perfect ever sense! Quote Link to comment Share on other sites More sharing options...
HaydnH Posted August 19, 2013 Share Posted August 19, 2013 Mine did it, Mines a 2006. Turned out to be the synchromesh, result was a rebuild. Grand total 2K from a stealer.... Was meant to be a warrenty job, but they revoked it after the work was done And you settled for that?!? I would've taken the car back from them and told them to go through the court if they wanted me to pay as they agreed prior to the work that it would be on warranty! Quote Link to comment Share on other sites More sharing options...
Deklan Posted August 19, 2013 Share Posted August 19, 2013 Took them though small claims and financial ombudsman, they faulted because of modifications. May i add not to the gearbox though Quote Link to comment Share on other sites More sharing options...
WhackyWill Posted August 19, 2013 Share Posted August 19, 2013 PM ZMANALEX.. ....Oil and Molyslip change., Just done mine about 2k miles ago not a problem since. Quote Link to comment Share on other sites More sharing options...
