[SOLD]BC Racing BR Series Coilovers
smudgedon
BC Racing BR Series Coilovers that have covered less than 15k from new
- Corner weight adjustment
- Ride height adjustment
- Damping adjustment
- Pillow ball (rose joint) upper mount
- Camber adjustment
- Corrosion protection
- High quality coil springs
- Patented concave lower locking collar
- High quality oil
- Nitrogen pressurised dampers
- Bearing mounted upper spring platform
The BR series coilovers use a large 46mm diameter piston in a 53mm diameter damper body to maximise oil capacity.
As the damper unit opearates the oil contained within heats up. The viscosity of oil changes as its temperature varies which can lead to changes in the damping characteristic of the unit.
BC Racing only use a very high quality oil with their coilovers but go that extra mile to maximise performance and build their BR range with a large 53mm diameter damper body. This increases the capacity of the unit which increases the volume of oil contained which in turn reduces the peak temperature and so significantly improves damper performance.
Give the Zed a nice firm ride without being too harsh
Will clean them up before they go, small amount of surface rust which is obviously normal. Otherwise these are good as new
RRP brand new is £689 from Redline, asking for £450 collected or £470 delivered
Discount for buying with front or rear camber arms that can be found here:
http://www.350z-uk.c...nt-camber-arms/
http://www.350z-uk.c...ar-camber-arms/
Edited by smudgedon
