mattfinch Posted July 24, 2013 Share Posted July 24, 2013 Hi all Just wondering if this happens to any one else. Every now and then I start my drive and about 2mins in the in car heater blowers blast air out at speed for about 10sec then turn off. Anyone know if this is a normal thing, only been doing it when the weather has been hot did not know if its the car telling me it wants the air con on lol. Thanks Quote Link to comment Share on other sites More sharing options...
theheff Posted July 24, 2013 Share Posted July 24, 2013 Have you had the centre console out at all recently. Pull the gear stick surround up and pull it out a little. You may find that the ribon cable has come loose from the heater controls. Quote Link to comment Share on other sites More sharing options...
mattfinch Posted July 24, 2013 Author Share Posted July 24, 2013 (edited) Yes I had it all out when I changed my head unit. Was very hard/tight to get it all back in so may be something to do with that then. But that was months ago and this has only started doing this over the last few weeks. Edited July 24, 2013 by mattfinch Quote Link to comment Share on other sites More sharing options...
Pnthrblkzs Posted July 24, 2013 Share Posted July 24, 2013 Is the heater dial set to auto, could just be adjusting the temperature as and when required? If not, when i changed my headunit i forgot 1st time to plug back in the heater ribbon and the blowers went a bit crazy when i started the car, so worth checking that ribbon Quote Link to comment Share on other sites More sharing options...
mattfinch Posted July 24, 2013 Author Share Posted July 24, 2013 Everything is set to off. I think I will have to take a look at the ribbon see if its come a bit loose. Cheers for the help Quote Link to comment Share on other sites More sharing options...
