How do i remove this cover for moulding!
Brettster
Think the removal is easy to get the whole Speedo out
I found this if it's of any help
10 min job , undo 4 screws that keep shroud around steering column, first pop out trim ring round ignition switch...  then there are 4,  10mm head bolts that retain speedo assy to the steering column undo these (they are a bit fiddly and you will need a small ratchet with longish extension bar to get at the front ones )  and thats it just unplug the single electrical connector and the speedo assy will be in your hand
