Reverse Dipping Mirrors
Cozzi
I have read the mirrors on the Import dip when selecting reverse.
I have the folding mirrors, but they do not seem to dip. Is it something you have to set up or a common problem with them failing?
Thanks in advance
  • 5 years later...
Hello I had the same problem and then I found the “auto” button and it works again also if you put the mirror button to the right position and you use your key fob to lock the car your mirrors will fold in and when you start the car they will unfold hope this helps :)
Edited by Mugends
