centre console illumination!
RDON
hi fellow zeders :) I have a query that is bothering me! the three centre console buttons below the radio have illumination lights that are bright and easy to see but when I put my head lights on they dim down and make them nearly impossible to see, should it be like that? does any body else do the same?
It's probably because they need to be brighter to be seen during the day and if you're turning the headlights on it's getting dark out, therefore a dimmer light will do the same job. You can adjust the brightness of the display using the buttons on the right of the binnacle.
Matt's right, button on the right of your dials adjusts the brightness of the display! But remember, the less bright any dials or switches are at night, the less likely you'll be distracted from the driving :p
