Niko Posted July 22, 2013 Share Posted July 22, 2013 Hi everyone I'm getting a set of oem seats with no airbags and no electrics. I've found a guide on here. But it looks like a bit of a pain. Can you just buy a resistor that just plugs in? Only asking coz I'm meeting up and doing the swap so could do with it being easy If anyone knows were i can get some from It would be aappreciated Quote Link to comment Share on other sites More sharing options...
KyleR Posted July 22, 2013 Share Posted July 22, 2013 Maplin sell them, it's just a run of the mill resistor, I'll go see which one now... Quote Link to comment Share on other sites More sharing options...
KyleR Posted July 22, 2013 Share Posted July 22, 2013 You'll need 2 x 2.2 ohm 1/4 or 1/2 watt resistors and just spice them into the loom before the connector. Don't turn the ignition on from the second the plugs are disconnected or you'll have to do the airbag reset Quote Link to comment Share on other sites More sharing options...
Niko Posted July 22, 2013 Author Share Posted July 22, 2013 You'll need 2 x 2.2 ohm 1/4 or 1/2 watt resistors and just spice them into the loom before the connector. Don't turn the ignition on from the second the plugs are disconnected or you'll have to do the airbag reset So its not just a plug in then. :-( Quote Link to comment Share on other sites More sharing options...
