Emz350Z Posted July 19, 2013 Share Posted July 19, 2013 Hi All, I have had a red flashing airbag light on my dashboard for a while now. I asked my mechanic to look into it but he said I need to take it to Nissan to have a diagnosis test done with the correct diagnosis equipment. Does anyone have or know anyone with this equipment? I haven't been too impressed with Nissan as I just can't get over the ridiculous quotes that they give me! Thanks, Emma Quote Link to comment Share on other sites More sharing options...
Flex Posted July 19, 2013 Share Posted July 19, 2013 If it's the same issue as mine it's just a lose connector, I need to take the seat out and replace the connector as it's doing my napper in. Once you've firmed up the connector you can do the pedal dance to reset and it'll go away. Quote Link to comment Share on other sites More sharing options...
Flex Posted July 19, 2013 Share Posted July 19, 2013 http://www.350z-uk.com/topic/72592-passenger-under-seat-airbag-connections/#entry1082159 Quote Link to comment Share on other sites More sharing options...
ph 7 Posted July 19, 2013 Share Posted July 19, 2013 Just give all of the plugs a squeeze and follow the air bag reset proceedure and fingers crossed you will be ok. If you have anything bouncing around the footwell it can set the light off, happened to me 3 times now 1 Quote Link to comment Share on other sites More sharing options...
Sly@Kaizer Motor Posted July 19, 2013 Share Posted July 19, 2013 If you are close to my workshop pop in for a free check Quote Link to comment Share on other sites More sharing options...
hensh65 Posted July 19, 2013 Share Posted July 19, 2013 common issue, just turn it off, turn the key round until the air bag light goes off and turn car off again. Do it 4 times and it will reset. However it will come back on, I am still scratching my head trying to work out what is happening to turn it back on Quote Link to comment Share on other sites More sharing options...
Flex Posted July 19, 2013 Share Posted July 19, 2013 common issue, just turn it off, turn the key round until the air bag light goes off and turn car off again. Do it 4 times and it will reset. However it will come back on, I am still scratching my head trying to work out what is happening to turn it back on I refer to my earlier post Quote Link to comment Share on other sites More sharing options...
Emz350Z Posted July 20, 2013 Author Share Posted July 20, 2013 Sorry for the late reply! Flying about with work. Thanks all for your help. Will definitely give that reset a go when I get home and will let you know how I get on! Thanks again! Quote Link to comment Share on other sites More sharing options...
K370Z2 Posted July 20, 2013 Share Posted July 20, 2013 My old 350Z had the same problem, My auto electrician said it was the same problem with a lot of the 3 series BMW's cut a long story short Bypassed the warning light still ok if you were unlucky enough to be in a crash. Heated seats dry out the connections. Once done no further problems. No Crashes!!!!!! Quote Link to comment Share on other sites More sharing options...
