ioneabee Posted August 3, 2013 Share Posted August 3, 2013 ok - that bit worked fine disk number 1 in (map update) - estimated time to completion - 111minutes Quote Link to comment Share on other sites More sharing options...
robin c Posted August 3, 2013 Share Posted August 3, 2013 I would be up for joining the chain and sharing the dvd love. how do I get added? Really useful for Europe trips as my Nav had a few wobbly moments this year. Just glad I can still read a paper map:) Quote Link to comment Share on other sites More sharing options...
Will370z Posted August 3, 2013 Share Posted August 3, 2013 Good luck with it andy, let meknow how it goes, my cds arrived at my parents so will look into it when i get back there. Happy to pass on the cds when im done. 1 Quote Link to comment Share on other sites More sharing options...
cs2000 Posted August 3, 2013 Share Posted August 3, 2013 Whey someone tried them out! Lol Yep the maps update is a fat one. The rough time people talk about is 2 hrs. Better fill up with fuel as you need to leave the car running! Quote Link to comment Share on other sites More sharing options...
Suits Posted August 3, 2013 Share Posted August 3, 2013 Will - Once you're done and happy to send them on, I'll take them if that's cool. Obviously once I'm done I will pass them on again . :teeth: :teeth: :teeth: Quote Link to comment Share on other sites More sharing options...
K370Z2 Posted August 3, 2013 Share Posted August 3, 2013 More then willing to share if anybody gets one that works and pass's it to me after all " its only fair to share " £300 from the main dealer reverybody know that just a rip off Quote Link to comment Share on other sites More sharing options...
cs2000 Posted August 3, 2013 Share Posted August 3, 2013 (edited) Guys, just had a pm from Andy. It seems disk 2 gets stuck and leaves half installed maps, which means no navigation . I'm going to try and get something sorted. For now, it's fine to install the disk 0, but avoid doing the map updates, need to find out what's up. Edited August 3, 2013 by cs2000 Quote Link to comment Share on other sites More sharing options...
Will370z Posted August 3, 2013 Share Posted August 3, 2013 Good to hear you are looking into it, wouldnt want to bugger up my sat nav. Hope you get it sorted andy. Quote Link to comment Share on other sites More sharing options...
Dogfather Posted August 4, 2013 Share Posted August 4, 2013 If the issues for disc 2 get resolved I would be really interested in borrowing the CD's from somebody, of course I'll pass them on to the next user! Cheers Tom Quote Link to comment Share on other sites More sharing options...
cs2000 Posted August 4, 2013 Share Posted August 4, 2013 (edited) I have another copy of disk 2 which il post out to him Monday. Hopefully this works. If so il create copies for you all and send out. Got another plan if this fails too. EDIT: Quick one just to say the re-burnt disk 2 worked for Andy, but now he's stuck on disk 3, defiantly hold off on these updates guys for now but chuck away disk 2 and disk 3, they're useless. Disk 0 and Disk 1 work fine, and disk 4 MAY work. I'm re-burn another set of disk 2's using the method that worked for Andy, then il test disk 3 with him and disk 4 if necessary. Il post the fixed CD's out to you guys as soon as I know what works and what doesn't. The updates will eventually work, it just seems as though the DVD's all need burning at a very slow speed for some reason, each disk takes roughly 15 mins compared to 3 if burnt at full speed. Edited August 6, 2013 by cs2000 Quote Link to comment Share on other sites More sharing options...
cs2000 Posted August 7, 2013 Share Posted August 7, 2013 Can the other 4 members who have had the nav disks from me just drop me a PM with your address again please. ive remembered three people, you should have a PM already, but forgot one name, applogies. Quote Link to comment Share on other sites More sharing options...
ioneabee Posted August 7, 2013 Share Posted August 7, 2013 to add to Chris' notes above - clearly in the instructions it says don't turn off engine etc during install process this isn't actually an issue - 'cos I obviously haven't left the car running for 3 days if need be, finish one disc, and you can put the next one in the next day and it just carries on. also during the instal (for me) the disc failed half way through - putting in the replacement (thanks Chris), it carried on from the point of fail - it didn't start all over again - so at the moment I'm about 75-80% through the process Quote Link to comment Share on other sites More sharing options...
ioneabee Posted August 8, 2013 Share Posted August 8, 2013 Yeehaaa All resolved and working Will update later when I get home Quote Link to comment Share on other sites More sharing options...
cs2000 Posted August 8, 2013 Share Posted August 8, 2013 Yeehaaa All resolved and working Will update later when I get home Thank god! let me know which dvd 4 worked and I can fix everyone else now Back to your harry potter books Andy! 1 Quote Link to comment Share on other sites More sharing options...
ioneabee Posted August 8, 2013 Share Posted August 8, 2013 yes - a few betty swollocks moments but Chris was a star original disks 0, 1 & 4 all work fine replacement disks 2 & 3 were needed As I said above, you can switch the engine off between disks and it picks up where it left off - same when the disk failed halfway through - on putting the new ones in it just carried on from the point of failure and not back to the start The original disk 3 must have failed right at the end, because once the new one was in, it finished in 4 minutes - disk 4 then took another 4 minutes. so with Chris' permission, I'll bundle up the "working" set to the first person to PM me and post back here Quote Link to comment Share on other sites More sharing options...
ioneabee Posted August 8, 2013 Share Posted August 8, 2013 ps it also appears to have resolved my issue with not correctly identifying what was playing on the radio - track ident (or something like that) is now working as it used to Quote Link to comment Share on other sites More sharing options...
cs2000 Posted August 8, 2013 Share Posted August 8, 2013 Excellent mate thanks SO much for your patience with it, and me Chuck the dead ones and get the good ones in the box and pass it on! Everyone else, il burn a new set of the duff DVD's as explained in your PM you should all have (apart from 1 person as I forgot their name). Please bin disk 2 and 3 and replace them with the ones il post tomorrow Quote Link to comment Share on other sites More sharing options...
Will370z Posted August 8, 2013 Share Posted August 8, 2013 Great work guys, i will wait for replacements and give it a whirl. Thanks for the hard work cs and thanks for being the guinea pig andy 1 Quote Link to comment Share on other sites More sharing options...
cs2000 Posted August 8, 2013 Share Posted August 8, 2013 No probs, just to make it open, here's the list of awaiting members as I see it. 1. Suits 2. Harryjax 3. elfman (possibly, someone would need to PM him to confirm) 4. garethkd1 5. robin c 6. K370Z2 7. Dogfather Quote Link to comment Share on other sites More sharing options...
ioneabee Posted August 8, 2013 Share Posted August 8, 2013 guinea pig andy :wacko: Quote Link to comment Share on other sites More sharing options...
Suits Posted August 8, 2013 Share Posted August 8, 2013 No probs, just to make it open, here's the list of awaiting members as I see it. 1. Suits 2. Harryjax 3. elfman (possibly, someone would need to PM him to confirm) 4. garethkd1 5. robin c 6. K370Z2 7. Dogfather Gents - I'm out. I don't have a Connect Premium like you class toppers, I have the older version, lol. :teeth: :teeth: :teeth: Quote Link to comment Share on other sites More sharing options...
cs2000 Posted August 8, 2013 Share Posted August 8, 2013 Shame, but list updated 1. Harryjax 2. elfman (possibly, someone would need to PM him to confirm) 3. garethkd1 4. robin c 5. K370Z2 6. Dogfather 1 Quote Link to comment Share on other sites More sharing options...
Adrian@TORQEN Posted August 8, 2013 Share Posted August 8, 2013 For people that have doubts about what SatNav option they have in the 370z, have a look here: http://www.satnavi.com/nissan.php 1 Quote Link to comment Share on other sites More sharing options...
Suits Posted August 9, 2013 Share Posted August 9, 2013 Yes, that's the sucker, Nissan Option 1 . Quote Link to comment Share on other sites More sharing options...
Adrian@TORQEN Posted August 9, 2013 Share Posted August 9, 2013 Ordered it, if it works I don't mind pass it along to other members Quote Link to comment Share on other sites More sharing options...
