Dave-350 Posted July 16, 2013 Share Posted July 16, 2013 Sorry, hopefully someone can help... 19x10+6, 19x8 -43, 5x114.3 I have spacers if needed, also I need to know good tyre sizes with a little stretch. Quote Link to comment Share on other sites More sharing options...
Ian Posted July 16, 2013 Share Posted July 16, 2013 You really won't need spacers with those the +6 would work with a bit of arch work & camber adjustment The -43, not a hope in hell unless your widebody Quote Link to comment Share on other sites More sharing options...
Dave-350 Posted July 16, 2013 Author Share Posted July 16, 2013 You really won't need spacers with those the +6 would work with a bit of arch work & camber adjustment The -43, not a hope in hell unless your widebody Oh really? that's gutting! Quote Link to comment Share on other sites More sharing options...
buster Posted July 16, 2013 Share Posted July 16, 2013 (edited) Edited July 16, 2013 by buster Quote Link to comment Share on other sites More sharing options...
Dave-350 Posted July 16, 2013 Author Share Posted July 16, 2013 Ok, so will these stick miles out on the front or are they really weak? Quote Link to comment Share on other sites More sharing options...
Sized Posted July 16, 2013 Share Posted July 16, 2013 See Ian's comment again buddy Quote Link to comment Share on other sites More sharing options...
Dave-350 Posted July 16, 2013 Author Share Posted July 16, 2013 See Ian's comment again buddy Yea I can read. But I've also been told I would need 40mm spacers... So I'm confused. Quote Link to comment Share on other sites More sharing options...
Ian Posted July 16, 2013 Share Posted July 16, 2013 Whoever told you that they needed spacers is an idiot Quote Link to comment Share on other sites More sharing options...
Humpy Posted July 16, 2013 Share Posted July 16, 2013 Whoever told you that they needed spacers is an idiot No need to be rude about me Ian * Ps wasnt me really Quote Link to comment Share on other sites More sharing options...
DoogyRev Posted July 16, 2013 Share Posted July 16, 2013 So this is what -23 (F) and -25 ® looks like . . . . with probably a lot of arch work and camber -43 . . . . . Quote Link to comment Share on other sites More sharing options...
DoogyRev Posted July 16, 2013 Share Posted July 16, 2013 http://www.stancenation.com/2012/09/02/focused-on-the-fitment-mannys-neckbreaking-350z/ Just in case you like it and want more pics Quote Link to comment Share on other sites More sharing options...
Pete87 Posted July 17, 2013 Share Posted July 17, 2013 So this is what -23 (F) and -25 ® looks like . . . . with probably a lot of arch work and camber -43 . . . . . Those pictures are miss leading tho as he is running an 11.5" rim on the front and a 12" rim on the back so his wheels will sit no where near where they do on the USA zed. Quote Link to comment Share on other sites More sharing options...
Pete87 Posted July 17, 2013 Share Posted July 17, 2013 (edited) I would work it out on an offset calculator I think you would be ok on the rears and I think you might even get away with the fronts if you had all your arches rolled and possible pulled. Just worked it out for you the front wheel will sit 73mm further out, so put a ruler on your wheel and see where the new wheel would sit if it is more than 10-20mm out of the arch I wouldn't try fitting them. Edited July 17, 2013 by Pete87 Quote Link to comment Share on other sites More sharing options...
S1 HNK Posted July 17, 2013 Share Posted July 17, 2013 Don't bother, you'll have to go back to the drawing board. Quote Link to comment Share on other sites More sharing options...
Keyser Posted July 17, 2013 Share Posted July 17, 2013 Whoever told you that they needed spacers is an idiot Thats nearly as bad as trying to sell a set of 11" wide RE30's and saying - "yer they will fit on a Zed" Quote Link to comment Share on other sites More sharing options...
Ian Posted July 17, 2013 Share Posted July 17, 2013 Whoever told you that they needed spacers is an idiot Thats nearly as bad as trying to sell a set of 11" wide RE30's and saying - "yer they will fit on a Zed" They would fit on a normal Z Quote Link to comment Share on other sites More sharing options...
flamez Posted September 18, 2013 Share Posted September 18, 2013 (edited) these wheels were off a wide bodied zed You can run them if you fit wide arches and 25mm spacers on the back, no need for any stretched tyres Edited September 18, 2013 by flamez Quote Link to comment Share on other sites More sharing options...
choptop Posted September 19, 2013 Share Posted September 19, 2013 "of course they will fit sir. That is £2000.......and we only take cash sir" Quote Link to comment Share on other sites More sharing options...
docwra Posted September 20, 2013 Share Posted September 20, 2013 Anything will fit if you try hard enough, but theres no way in hell you would get brakes under 8J - ET43 without spacers, I reckon you would need at least another 25mm on the arch as well. 10 ET6 is easy, almost goes under a standard arch. BTW, I run 10 ET -43 on the front of my car, it can be done Quote Link to comment Share on other sites More sharing options...
Jetpilot Posted September 22, 2013 Share Posted September 22, 2013 although they wont fit would love to see Quote Link to comment Share on other sites More sharing options...
