japz Posted July 12, 2013 Share Posted July 12, 2013 Hi, I'm looking at buying the set of front and rear Eibach wheel spacers: http://cougarstore.co.uk/index.php?main_page=product_info&cPath=1_18&products_id=30 But wanted to ask, are these simply bolt on or do you have to remove the hub and install longer studs? It was hard to tell from the pic. Many Thanks 1 Quote Link to comment Share on other sites More sharing options...
MITZ@CougarStore Posted July 12, 2013 Share Posted July 12, 2013 These are very easy to install, no need to press out the OEM studs as the spacers come with studs pressed in, so remove wheel, fit spacer, used supplied nuts to attach the spacer, fit wheel on the spacer and you're done... An excellent mod that's really effective... Quote Link to comment Share on other sites More sharing options...
DoogyRev Posted July 12, 2013 Share Posted July 12, 2013 They will just be bolt on Not sure if thats the correct pic Should look like this . . . Quote Link to comment Share on other sites More sharing options...
japz Posted July 12, 2013 Author Share Posted July 12, 2013 (edited) Great! Thanks for the swift replies. I think I will be putting an order in sometime next week in that case. I had some HR spacers on a 200sx and they were a pain in the ass to fit, these sound much better. I presume you have them in stock, how long does delivery take roughly? Edited July 12, 2013 by japz Quote Link to comment Share on other sites More sharing options...
MITZ@CougarStore Posted July 12, 2013 Share Posted July 12, 2013 Available as we speak, we usually use Parcelforce or DPD, who operate on a next working day delivery... Quote Link to comment Share on other sites More sharing options...
japz Posted July 12, 2013 Author Share Posted July 12, 2013 Fantastic, thanks again. Looking forward to ordering these now. Quote Link to comment Share on other sites More sharing options...
MITZ@CougarStore Posted July 12, 2013 Share Posted July 12, 2013 You're welcome, have a good weekend... Quote Link to comment Share on other sites More sharing options...
Dayy Posted July 23, 2013 Share Posted July 23, 2013 While we are on the topic of Spacers from CS, I was wondering. What is the difference between the 4 different types you sell? Is it as simple as one being front and back at different sizes, one being a pair at the same size and the other two being front and back separate? Quote Link to comment Share on other sites More sharing options...
MITZ@CougarStore Posted July 23, 2013 Share Posted July 23, 2013 Dayy, as you have the RAYS wheel fitted, the 20mm front and 25mm rear are the ones you should opt for, this set here - http://cougarstore.co.uk/index.php?main_page=product_info&products_id=30&zenid=bcaa60565806895c2c0f2d2ff1b32aee Quote Link to comment Share on other sites More sharing options...
spursmaddave Posted July 23, 2013 Share Posted July 23, 2013 2 things.... You have to remove the bolt on the front to prevent fitting rear wheels in front Don't over tighten the bolts on the spacers they are a bugger to get off, best to put a bit of copper grease behind them too 1 Quote Link to comment Share on other sites More sharing options...
veilside z Posted July 23, 2013 Share Posted July 23, 2013 Pics when fitted please Quote Link to comment Share on other sites More sharing options...
ScottyZ Posted August 11, 2013 Share Posted August 11, 2013 2 things.... You have to remove the bolt on the front to prevent fitting rear wheels in front Don't over tighten the bolts on the spacers they are a bugger to get off, best to put a bit of copper grease behind them too As I found out - much to my annoyance! Mine were a right bugger to get off because I'd massively over tightened them. Quote Link to comment Share on other sites More sharing options...
zabba Posted August 12, 2013 Share Posted August 12, 2013 Do these alter the Geo at all? If I wanted to get some would I have to factor in cost for a new allignment? Quote Link to comment Share on other sites More sharing options...
japz Posted October 7, 2013 Author Share Posted October 7, 2013 (edited) Hi Guys, I finally got around to ordering these last week! Nice and easy to fit, the car looks so much better now. Happy customer, Many Thanks Edited October 7, 2013 by japz Quote Link to comment Share on other sites More sharing options...
