smellstevens Posted July 12, 2013 Share Posted July 12, 2013 I got in the car today and when I started it up the oil pressure gauge went to the maximum position, past the 120 mark. This was the first start of the day and drove completely fine. I thought maybe the dial was shagged but when I turn car off it drops normally so maybe a sensor? Anyone else had this issue? Easy fix? Cheers Quote Link to comment Share on other sites More sharing options...
nowhereboy Posted July 12, 2013 Share Posted July 12, 2013 As far as I know high oil pressure on start up is normal?? Mine does it too. Quote Link to comment Share on other sites More sharing options...
DoogyRev Posted July 12, 2013 Share Posted July 12, 2013 +1 will be higher when you first start the car, then move up and down depending on how far you press the loud pedal. Have you checked the oil levels? Quote Link to comment Share on other sites More sharing options...
smellstevens Posted July 12, 2013 Author Share Posted July 12, 2013 Yeah it has been moving but now it stays at the very top doesn't even wobble Quote Link to comment Share on other sites More sharing options...
DoogyRev Posted July 12, 2013 Share Posted July 12, 2013 How much oil is in your car? Quote Link to comment Share on other sites More sharing options...
lmc Posted July 12, 2013 Share Posted July 12, 2013 Oil pressure sensor Had the same problem with mine. Be careful if you are going to change it yourself its a tapered thread and will be an expensive mistake if it;s done wrong trust me Quote Link to comment Share on other sites More sharing options...
AMT Posted July 12, 2013 Share Posted July 12, 2013 The guage always starts high until the cars settled and warmed up. its goes down. if it doesn't after so many minutes of driving...then you might have an issue lol Quote Link to comment Share on other sites More sharing options...
