Rear speakers
Dannyg
how easy is it to replace the rear speakers?
Does all the trim just clip off?
Yes, the speaker trim just clips off.......after you first take the rear of the door trim and lift it so you can get to the rear quarter trim, loosen then rear quarter trim lower half, do the same on the other side, pop them both all the way to the back and remove, then loosen center tunnel and raise, so that the cover piece over the sub and glove box can come out, and then finally you can unpop the top cover and undo the tabs that hold the speaker trim, of which two are plastic welded
