front bumper grill template
RDON
hi folks. quick question!! does anyone have a template for the front grill bumper that they could send to speed up my new project! I am going to manufacture a stainless steel grill with either holes, squares of ovals, not quite decided yet will decide as I draw it. but it would really help if a member had a template so I can make proto types easier then? thanks guys.
so with the Zun sport do you have to cut away the existing grill bars and mounts to fit that?
On the facelift you need to remove the painted slat covers. A bit of a pain but can be done by reaching down from the top through the hole where the bonnet catch is and unscrewing the screws.
The Zunsport grille fits directly into the grille opening and you fix it by screwing through the grille directly into the plastic slats you revealed when you removed the painted covers. The Zunsport has 4 mounting guides on the back, can't really go wrong.
David
Edited by Tinyflier
ahh ok David sounding promising!! so I could use the Zun sport I guess as an external size template and then look at making the grill to existing OEM fitments. Any chance you could draw round it and send me the template please?
No problem, will do that tomorrow evening and get it in post ASAP. PM me your address please.
David
