Scene Posted July 2, 2013 Share Posted July 2, 2013 Ive just received my Fortune Auto X Broadway Static coilovers from the states, and being a true coilover configuration I'm now on the lookout for some rear toe arms to replace the spring buckets. Can anybody point me the right direction to some from the UK? Ive had a look and found Stillen ones from Tarmac Sportz but at £400 theyre super expensive! All the other ones ive found are from the States, or the bolts and washers to use with the OEM bucket which confuses searches on google as all im getting is camber arms and bolt kits :/ Any help would be great! cheers Quote Link to comment Share on other sites More sharing options...
evilscorp Posted July 2, 2013 Share Posted July 2, 2013 Have you reinforced the top mounts? Quote Link to comment Share on other sites More sharing options...
Scene Posted July 2, 2013 Author Share Posted July 2, 2013 The coilovers come with all new top mounts so thats all sorted Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted July 2, 2013 Share Posted July 2, 2013 It is the rear suspension turrets that require reinforcing for a true coil over set up. Alex. Quote Link to comment Share on other sites More sharing options...
Scene Posted July 2, 2013 Author Share Posted July 2, 2013 Zman do you have any info on this at all? I didnt realize this was the case? Quote Link to comment Share on other sites More sharing options...
Mark@Abbey m/s Posted July 2, 2013 Share Posted July 2, 2013 Stock car puts the force from the springs through the chassis legs. Converting to true coil overs puts the load through the turrets which only normally takes damper load. You need to reinforce the turrets to take the spring load as well. Simple to do but does take time. Quote Link to comment Share on other sites More sharing options...
MeisterR Posted July 4, 2013 Share Posted July 4, 2013 (edited) If you want the rear toe arms, we have them in stock. The MeisterR Zeta-R coilovers is a true coilover design also. http://www.cyberspee...ex&cPath=77_124 Jerrick Edited July 4, 2013 by MeisterR Quote Link to comment Share on other sites More sharing options...
