paulashy Posted July 2, 2013 Share Posted July 2, 2013 Just got back from a trip to the ring, the first time I have had the 350z on track and I found that the abs would kick in on the front right when light braking. Just had brand new discs, pads, braided lines and fluid. Any one else had this problem or know what it might be? Or is it just getting use to the abs in the 350z? Quote Link to comment Share on other sites More sharing options...
Suits Posted July 2, 2013 Share Posted July 2, 2013 The Ring is like an ice rink in some places so could just be worn tarmac mate. If everything you say is new, you should be biting and working well. Quote Link to comment Share on other sites More sharing options...
Terence Bower Posted July 10, 2013 Share Posted July 10, 2013 Just got back from a trip to the ring, the first time I have had the 350z on track and I found that the abs would kick in on the front right when light braking. Just had brand new discs, pads, braided lines and fluid. Any one else had this problem or know what it might be? Or is it just getting use to the abs in the 350z? Do you have grooved/dimpled disc's fitted? If so that is more than likely what you are feeling. Was yours the darker silver car?Saw one around several times,mainly in Adenau. Quote Link to comment Share on other sites More sharing options...
Oz Striker Posted July 18, 2013 Share Posted July 18, 2013 Your a brave bastard with big cajones, if the first place you took your Z was the ring! Do you have the recommended staggered tyre setup? Quote Link to comment Share on other sites More sharing options...
