Are these brake pads ok.........
jollyranchers
Had the front brake pads out earlier , ive bought Brembo replacements however they are slightly different and have a grove down the middle.
Has anyone else found this ?
Do I need new anti squeal rubber shims ? the new brembo pads don't have them stuck on the back.
Edited by jollyranchers
its weird the ones that came out have the diagonal line in the pad , the brand newy's don't. I can also only see one part number for the Brembo's for the front. Maybe Brembo changed the pad pattern ?
Will get some shims sorted :)
How easy are the pistons to push back ? , without sounding retarded im assuming i need to push back each individual piston with a G clamp
That's how I did it. Take cap off reservoir and use g clamps to push all pistons back then when you take them off they should move much.
Just curious, why wouldn't you re-use the original shims?
I've always done this on my bikes without issue.
Same here - just re-use the old ones after cleaning them up and a dab of copper grease (and they're metal, not rubber).
