370Ad Posted November 6, 2013 Share Posted November 6, 2013 The Z is getting cheaper so people are bound to start cutting corners....you can see it with the for sale ad's as well. 1 Quote Link to comment Share on other sites More sharing options...
Dblock Posted November 6, 2013 Share Posted November 6, 2013 The Z is getting cheaper so people are bound to start cutting corners....you can see it with the for sale ad's as well. How is it cutting corners? Do you not understand there is more choice, less weight, better turn in due to less sidewall etc etc. I'm running Pilot super sports I don't see how that is cutting corners? What tyres do you run? 1 Quote Link to comment Share on other sites More sharing options...
370Ad Posted November 7, 2013 Share Posted November 7, 2013 The Z is getting cheaper so people are bound to start cutting corners....you can see it with the for sale ad's as well. How is it cutting corners? Do you not understand there is more choice, less weight, better turn in due to less sidewall etc etc. I'm running Pilot super sports I don't see how that is cutting corners? What tyres do you run? Because you are not buying the correct tyre size which was designed for the car? So the speedometer, mileage, traction control, torque and gearing settings are all based on the distance that the tyre travels over one complete revolution. A tyre with a different outside diameter will travel a different distance over that one revolution with a different amount of torque. For an extra £30 a corner why not put the correct size tyres on? It doesn't matter if they are bloody F1 tyres....if they are the wrong size its a waste of time.... I agree that it might not make 'that' much difference dropping the profile down by 5 but it is cutting corners Quote Link to comment Share on other sites More sharing options...
Ekona Posted November 7, 2013 Share Posted November 7, 2013 I can see both sides on this one tbh. Dropping a profile will make no difference to the car in terms of maintenance, on the caveat that your particular car is okay with it regarding TCS. Speedo & mileage will be affected, but not by anywhere near as much as I would consider worthy of note. To ignore that completely though would be folly. Many people run 19" and even 20" wheels. These do not run stock tyre sizes and are again fractions out over the rolling radius, but will cause no further issues. I would rather run 40 profile MPSS than 45 profile 040s. One may be the correct OEM tyre choice, but that doesn't make it the best choice. Tyre choice should be made on many parameters, but sticking rigidly with the OEM size is not one I would consider to be paramount*. *Not forgetting the TCS caveat, of course. Quote Link to comment Share on other sites More sharing options...
Ekona Posted November 7, 2013 Share Posted November 7, 2013 Also, I've never ever used the word 'folly' in its correct usage on an internet forum before. Huzzah for me! Quote Link to comment Share on other sites More sharing options...
AliveBoy Posted November 7, 2013 Share Posted November 7, 2013 The Z is getting cheaper so people are bound to start cutting corners....you can see it with the for sale ad's as well. How is it cutting corners? Do you not understand there is more choice, less weight, better turn in due to less sidewall etc etc. I'm running Pilot super sports I don't see how that is cutting corners? What tyres do you run? Because you are not buying the correct tyre size which was designed for the car? So the speedometer, mileage, traction control, torque and gearing settings are all based on the distance that the tyre travels over one complete revolution. A tyre with a different outside diameter will travel a different distance over that one revolution with a different amount of torque. For an extra £30 a corner why not put the correct size tyres on? It doesn't matter if they are bloody F1 tyres....if they are the wrong size its a waste of time.... I agree that it might not make 'that' much difference dropping the profile down by 5 but it is cutting corners So the speedometer - Use a sat nav for true speed as the car is out +/- 3% anyway, mileage - not exactly a huge concern as the effect will be tiny, traction control - If you really have an issue drive without it, if you rely on it you shouldn't be driving the car, torque - is produced by the engine and not the tyres, so the effect is miniscule and gearing settings - unless you're going from a 15" alloy to a 18" alloy the difference will again, tiny! are all based on the distance that the tyre travels over one complete revolution. - Over a mile the 45 profile will rotate 756.3 times, on the 40 profile the tyre will rotate 784.6 times. Not a huge difference! A tyre with a different outside diameter will travel a different distance over that one revolution with a different amount of torque. Speedo differences for you: 20 - 19.3 30 - 28.9 40 - 38.5 50 - 48.1 60 - 57.8 70 - 67.4 80 - 77 90 - 86.6 2 Quote Link to comment Share on other sites More sharing options...
370Ad Posted November 7, 2013 Share Posted November 7, 2013 The Z is getting cheaper so people are bound to start cutting corners....you can see it with the for sale ad's as well. How is it cutting corners? Do you not understand there is more choice, less weight, better turn in due to less sidewall etc etc. I'm running Pilot super sports I don't see how that is cutting corners? What tyres do you run? Because you are not buying the correct tyre size which was designed for the car? So the speedometer, mileage, traction control, torque and gearing settings are all based on the distance that the tyre travels over one complete revolution. A tyre with a different outside diameter will travel a different distance over that one revolution with a different amount of torque. For an extra £30 a corner why not put the correct size tyres on? It doesn't matter if they are bloody F1 tyres....if they are the wrong size its a waste of time.... I agree that it might not make 'that' much difference dropping the profile down by 5 but it is cutting corners So the speedometer - Use a sat nav for true speed as the car is out +/- 3% anyway, mileage - not exactly a huge concern as the effect will be tiny, traction control - If you really have an issue drive without it, if you rely on it you shouldn't be driving the car, torque - is produced by the engine and not the tyres, so the effect is miniscule and gearing settings - unless you're going from a 15" alloy to a 18" alloy the difference will again, tiny! are all based on the distance that the tyre travels over one complete revolution. - Over a mile the 45 profile will rotate 756.3 times, on the 40 profile the tyre will rotate 784.6 times. Not a huge difference! A tyre with a different outside diameter will travel a different distance over that one revolution with a different amount of torque. Speedo differences for you: 20 - 19.3 30 - 28.9 40 - 38.5 50 - 48.1 60 - 57.8 70 - 67.4 80 - 77 90 - 86.6 100% agree as stated in my post above it won't make that much difference with the profile drop we are talking about but it is cutting corners and more people will do it now the Z is getting cheaper I don't have standard tyre sizes as I run 19's but its the closest you can get them. Its less than 1% out aswell, where as this is 3.7% Quote Link to comment Share on other sites More sharing options...
Dblock Posted November 7, 2013 Share Posted November 7, 2013 (edited) The Z is getting cheaper so people are bound to start cutting corners....you can see it with the for sale ad's as well. How is it cutting corners? Do you not understand there is more choice, less weight, better turn in due to less sidewall etc etc. I'm running Pilot super sports I don't see how that is cutting corners? What tyres do you run? Because you are not buying the correct tyre size which was designed for the car? So the speedometer, mileage, traction control, torque and gearing settings are all based on the distance that the tyre travels over one complete revolution. A tyre with a different outside diameter will travel a different distance over that one revolution with a different amount of torque. For an extra £30 a corner why not put the correct size tyres on? It doesn't matter if they are bloody F1 tyres....if they are the wrong size its a waste of time.... I agree that it might not make 'that' much difference dropping the profile down by 5 but it is cutting corners What about buying wheels who pump out replicas? I personally don't have a problem with it but isn't it cutting corners? Surely you should stick to Oem wheels. Can't say much else the posts above are spot on. It makes such little difference to alot of thr stuff but makes a big difference to weight. Pick up a wheel with 45'd compared to 40's. Heavier which is unsparing weight. Less sidewall distortion so a more positive turn in. The also look way way way better. Edited November 7, 2013 by Dblock Quote Link to comment Share on other sites More sharing options...
370Ad Posted November 7, 2013 Share Posted November 7, 2013 (edited) The Z is getting cheaper so people are bound to start cutting corners....you can see it with the for sale ad's as well. How is it cutting corners? Do you not understand there is more choice, less weight, better turn in due to less sidewall etc etc. I'm running Pilot super sports I don't see how that is cutting corners? What tyres do you run? Because you are not buying the correct tyre size which was designed for the car? So the speedometer, mileage, traction control, torque and gearing settings are all based on the distance that the tyre travels over one complete revolution. A tyre with a different outside diameter will travel a different distance over that one revolution with a different amount of torque. For an extra £30 a corner why not put the correct size tyres on? It doesn't matter if they are bloody F1 tyres....if they are the wrong size its a waste of time.... I agree that it might not make 'that' much difference dropping the profile down by 5 but it is cutting corners What about buying wheels who pump out replicas? I personally don't have a problem with it but isn't it cutting corners? Surely you should stick to Oem wheels. Can't say much else the posts above are spot on. It makes such little difference to alot of thr stuff but makes a big difference to weight. Pick up a wheel with 45'd compared to 40's. Heavier which is unsparing weight. Less sidewall distortion so a more positive turn in. The also look way way way better. Now your just being silly....these 'replica' wheels are a perfect fit for the car. They match all the right tolerances/specs needed, exactly the same as OEM wheels. Unfortunately the same can't be said for 40 to 45 profile. If the wheels had wobbly bolts then I get your point but they don't.... Just admit you cut a corner to save £120?! Go on it isn't that hard to say! I will go first if it helps....'I couldn't justify spending £2k+ on Volks so I bought Rotas instead'. Edited November 7, 2013 by 350Ad Quote Link to comment Share on other sites More sharing options...
StevoD Posted November 7, 2013 Share Posted November 7, 2013 (edited) The Z is getting cheaper so people are bound to start cutting corners....you can see it with the for sale ad's as well. How is it cutting corners? Do you not understand there is more choice, less weight, better turn in due to less sidewall etc etc. I'm running Pilot super sports I don't see how that is cutting corners? What tyres do you run? Because you are not buying the correct tyre size which was designed for the car? So the speedometer, mileage, traction control, torque and gearing settings are all based on the distance that the tyre travels over one complete revolution. A tyre with a different outside diameter will travel a different distance over that one revolution with a different amount of torque. For an extra £30 a corner why not put the correct size tyres on? It doesn't matter if they are bloody F1 tyres....if they are the wrong size its a waste of time.... I agree that it might not make 'that' much difference dropping the profile down by 5 but it is cutting corners What about buying wheels who pump out replicas? I personally don't have a problem with it but isn't it cutting corners? Surely you should stick to Oem wheels. Can't say much else the posts above are spot on. It makes such little difference to alot of thr stuff but makes a big difference to weight. Pick up a wheel with 45'd compared to 40's. Heavier which is unsparing weight. Less sidewall distortion so a more positive turn in. The also look way way way better. Now your just being silly....these 'replica' wheels are a perfect fit for the car. They match all the right tolerances/specs needed, exactly the same as OEM wheels. Just admit you cut a corner to save £120?! Go on it isn't that hard to say! I will go first if it helps....'I couldn't justify spending £2k+ on Volks so I bought Rotas instead'. apart from the fact there alot heavier than what the 'OEM' suspension and wheel bearings etc was designed to carry so your choice is more likely to wear out suspensions parts etc alot faster which i would say is more of a concern than a rolling radius change that wont effect anything other than speedo error, I know which one nissan would frown upon more from an oem manufacture point of view. Edited November 7, 2013 by StevoD 1 Quote Link to comment Share on other sites More sharing options...
370Ad Posted November 7, 2013 Share Posted November 7, 2013 The Z is getting cheaper so people are bound to start cutting corners....you can see it with the for sale ad's as well. How is it cutting corners? Do you not understand there is more choice, less weight, better turn in due to less sidewall etc etc. I'm running Pilot super sports I don't see how that is cutting corners? What tyres do you run? Because you are not buying the correct tyre size which was designed for the car? So the speedometer, mileage, traction control, torque and gearing settings are all based on the distance that the tyre travels over one complete revolution. A tyre with a different outside diameter will travel a different distance over that one revolution with a different amount of torque. For an extra £30 a corner why not put the correct size tyres on? It doesn't matter if they are bloody F1 tyres....if they are the wrong size its a waste of time.... I agree that it might not make 'that' much difference dropping the profile down by 5 but it is cutting corners What about buying wheels who pump out replicas? I personally don't have a problem with it but isn't it cutting corners? Surely you should stick to Oem wheels. Can't say much else the posts above are spot on. It makes such little difference to alot of thr stuff but makes a big difference to weight. Pick up a wheel with 45'd compared to 40's. Heavier which is unsparing weight. Less sidewall distortion so a more positive turn in. The also look way way way better. Now your just being silly....these 'replica' wheels are a perfect fit for the car. They match all the right tolerances/specs needed, exactly the same as OEM wheels. Just admit you cut a corner to save £120?! Go on it isn't that hard to say! I will go first if it helps....'I couldn't justify spending £2k+ on Volks so I bought Rotas instead'. apart from the fact there alot heavier than what the 'OEM' suspension and wheel bearings etc was designed to carry so your choice is more likely to wear out suspensions parts etc alot faster which i would say is more of a concern than a rolling radius change that wont effect anything other than speedo error, I know which one nissan would frown upon more from an oem manufacture point of view. They are lighter than the standard wheels so it would definitely be the tyres that are frowned upon...boom! 1 Quote Link to comment Share on other sites More sharing options...
StevoD Posted November 7, 2013 Share Posted November 7, 2013 Explain how a cast 19x10.5 with 275 (im guessing) weights less than a forged 18x8.5?? With a 245 Quote Link to comment Share on other sites More sharing options...
AliveBoy Posted November 7, 2013 Share Posted November 7, 2013 Explain how a cast 19x10.5 with 275 (im guessing) weights less than a forged 18x8.5?? With a 245 Guessing he didn't have rays, the non rays weigh the same as a small planet, so they probably would be lighter. I know they weigh a ton because I have 3 sets of the blighters Quote Link to comment Share on other sites More sharing options...
bizz Posted November 7, 2013 Share Posted November 7, 2013 I know they weigh a ton because I have 3 sets of the blighters Drifting!!!! Woohoo 1 Quote Link to comment Share on other sites More sharing options...
SkylineV35 Posted November 7, 2013 Share Posted November 7, 2013 (edited) Iv been running 235 35 19 front 255 35 19 rear on oem forged lightweight rays never had an issue with tc and it handles amazing oh tyres are michellin pilot sports, recently had a hortie for my rears so thought id try 40s on the rears this time... again no tc problems! Ride comfort is better too bonus! and theres a lil bit more rubber sticking out over the rim to stop me curbing lol compared to the 35s which sit flush with the rim. But each to there own but i think the 235 35 19 front and 255 40 19 rear on michellin pss are the best combo! Edited November 7, 2013 by SkylineV35 Quote Link to comment Share on other sites More sharing options...
Neilp Posted November 7, 2013 Share Posted November 7, 2013 Iv been running 235 35 19 front 255 35 19 rear on oem forged lightweight rays never had an issue with tc and it handles amazing oh tyres are michellin pilot sports, recently had a hortie for my rears so thought id try 40s on the rears this time... again no tc problems! Ride comfort is better too bonus! and theres a lil bit more rubber sticking out over the rim to stop me curbing lol compared to the 35s which sit flush with the rim. But each to there own but i think the 235 35 19 front and 255 40 19 rear on michellin pss are the best combo! oem rims are 18" matey, not 19 Quote Link to comment Share on other sites More sharing options...
SkylineV35 Posted November 7, 2013 Share Posted November 7, 2013 (edited) Iv been running 235 35 19 front 255 35 19 rear on oem forged lightweight rays never had an issue with tc and it handles amazing oh tyres are michellin pilot sports, recently had a hortie for my rears so thought id try 40s on the rears this time... again no tc problems! Ride comfort is better too bonus! and theres a lil bit more rubber sticking out over the rim to stop me curbing lol compared to the 35s which sit flush with the rim. But each to there own but i think the 235 35 19 front and 255 40 19 rear on michellin pss are the best combo! oem rims are 18" matey, not 19 Oh i mean for my Skyline 350gt, it had forged alluminium 19s as oem for 2005+ http://www.skylinesaustralia.com/forums/topic/414611-19-rays-coupe-wheels/ I think they would look amazing on a zed Edited November 7, 2013 by SkylineV35 Quote Link to comment Share on other sites More sharing options...
Neilp Posted November 7, 2013 Share Posted November 7, 2013 Iv been running 235 35 19 front 255 35 19 rear on oem forged lightweight rays never had an issue with tc and it handles amazing oh tyres are michellin pilot sports, recently had a hortie for my rears so thought id try 40s on the rears this time... again no tc problems! Ride comfort is better too bonus! and theres a lil bit more rubber sticking out over the rim to stop me curbing lol compared to the 35s which sit flush with the rim. But each to there own but i think the 235 35 19 front and 255 40 19 rear on michellin pss are the best combo! oem rims are 18" matey, not 19 Oh i mean for my Skyline 350gt, it had forged alluminium 19s as oem for 2005+ really? I never realised those were 19's ! Aw well happy days Quote Link to comment Share on other sites More sharing options...
SkylineV35 Posted November 7, 2013 Share Posted November 7, 2013 Iv been running 235 35 19 front 255 35 19 rear on oem forged lightweight rays never had an issue with tc and it handles amazing oh tyres are michellin pilot sports, recently had a hortie for my rears so thought id try 40s on the rears this time... again no tc problems! Ride comfort is better too bonus! and theres a lil bit more rubber sticking out over the rim to stop me curbing lol compared to the 35s which sit flush with the rim. But each to there own but i think the 235 35 19 front and 255 40 19 rear on michellin pss are the best combo! oem rims are 18" matey, not 19 Oh i mean for my Skyline 350gt, it had forged alluminium 19s as oem for 2005+ really? I never realised those were 19's ! Aw well happy days They do look like 17s from afar! I think cause my arches are massive lol Quote Link to comment Share on other sites More sharing options...
Neilp Posted November 7, 2013 Share Posted November 7, 2013 Iv been running 235 35 19 front 255 35 19 rear on oem forged lightweight rays never had an issue with tc and it handles amazing oh tyres are michellin pilot sports, recently had a hortie for my rears so thought id try 40s on the rears this time... again no tc problems! Ride comfort is better too bonus! and theres a lil bit more rubber sticking out over the rim to stop me curbing lol compared to the 35s which sit flush with the rim. But each to there own but i think the 235 35 19 front and 255 40 19 rear on michellin pss are the best combo! oem rims are 18" matey, not 19 Oh i mean for my Skyline 350gt, it had forged alluminium 19s as oem for 2005+ really? I never realised those were 19's ! Aw well happy days They do look like 17s from afar! I think cause my arches are massive lol lol probs! Great looking car though! 1 Quote Link to comment Share on other sites More sharing options...
370Ad Posted November 7, 2013 Share Posted November 7, 2013 Explain how a cast 19x10.5 with 275 (im guessing) weights less than a forged 18x8.5?? With a 245 I said standard not rays Quote Link to comment Share on other sites More sharing options...
StevoD Posted November 7, 2013 Share Posted November 7, 2013 Rays are standard imo Quote Link to comment Share on other sites More sharing options...
AliveBoy Posted November 7, 2013 Share Posted November 7, 2013 Rays are standard imo Bitch 1 Quote Link to comment Share on other sites More sharing options...
SamN Posted November 7, 2013 Share Posted November 7, 2013 Didn't Kyle compare the weights from 19" rota grid drifts and rays, and confirm that the rotas were only minimally heavier? In either case, rays plus spacers (to get the wider stance) must be similar weights to those rotas and would therefore cause the same extra strain on wheel bearings. Considering how awesome rota grid drifts look, they're definitely worth it in my opinion! Anyway back on topic for more pictures of 40 profiles?? 1 Quote Link to comment Share on other sites More sharing options...
370Ad Posted November 7, 2013 Share Posted November 7, 2013 Rays are standard imo Well they were a 1k extra on the DE so your wrong there! Anyway I have made my point, laters! Quote Link to comment Share on other sites More sharing options...
