benzed350 Posted June 27, 2013 Share Posted June 27, 2013 My gf's cooper s has developed an alarm problem. I think the battery has ran out in the fob. Doesn't seem to work at all. However you can stil lock the car with the key and the alarm seems to arm itself as the indicators flash. However when you unlock the car, it doesn't disarm, you get in and get out again very quickly due to the loud screaming noise in your ears. Any bright sparks got any ideas? Quote Link to comment Share on other sites More sharing options...
KC350Z Posted June 27, 2013 Share Posted June 27, 2013 Does the alarm stop if you turn the ignition on after getting in also does it disarm if unlocked with key not thob had same with r5 turbo was battery getting low in thob would work most times but same problem new battery and all good would arm but not disarm Quote Link to comment Share on other sites More sharing options...
KC350Z Posted June 27, 2013 Share Posted June 27, 2013 Ill also ask at work tomorrow and see if I can grab battery free as i make the intier for them etc Quote Link to comment Share on other sites More sharing options...
benzed350 Posted June 27, 2013 Author Share Posted June 27, 2013 Yea it stops if you put the key in the ignition, but doesn't disarm on the fob or key in the door. I put a new battery in it that I got out of something else. I tried a reprogramming thing offline but it still won't have it. Quote Link to comment Share on other sites More sharing options...
KC350Z Posted June 27, 2013 Share Posted June 27, 2013 Do you have spare key you can try then your know Quote Link to comment Share on other sites More sharing options...
