Plasti dip action (non zed)
scottyd
I purchased this to use on the zed but decided, after some persuasion to dip the girlfriends fiat 500 wheels.
I know quite a few people might be planning to use this on their zed so decided to post my experience
Quite impressed with the results ill be checking it to see how well it holds up :p
I used almost a can per wheel so if you we're to do 18 or 19" wheels 5 should be enough
Before
After 4 coats peeling off the excess plasti dip
The finished product. The finish is not matt but more of a satin which I prefer, its slightly textured close up. I think it could look better with a bit more practice at spraying (I'm a total novice!) I probably put it on too thick.
Needs lowering now.. :p
Edited by scottyd
