fault codes p1273 and p1283
mc
If you have both in the same time, than it's more likely to be one of the last 3 of these (official causes for this fault code):
  • Air fuel ratio (A/F) sensor 1
  • Air fuel ratio (A/F) sensor 1 heater
  • Fuel pressure
  • Fuel injector
  • Intake air leaks
So yes, probably air leak (or low fuel pressure, but check for air-leaks first).
Thanks for the info. I have cleared the codes for now, will see if it comes back and then check for intake leaks (after the airflow sensor I presume, guess I am looking for split hoses etc?)
Well the codes come back every second trip or so. It now sounds like I have an exhaust leak which is getting slowly worse.
Trying to stick my head under the car it appears to be forward of the y-pipe, but difficult to tell with the undertray in place. Could this be the problem or just coincidence?
Got the exhaust leak fixed, replaced the triangular gaskets between manifold and cats. Engine check light came back on this morning after staying off for a day. just 1283 this time so I'm hoping the ecu is relearning after running rich for a while...
Edited by mc
