What size spacers can/should I fit?
Ashton
Have ordered some 19" et43 wheels, 8.5 at the front and 10 wide at the back.
Do I need spacers firstly? And secondly what size of spacers should I fit?
Appreciate all advice.
8.5 x 19 with 245/35/19 fronts
10 x 19 with 275/35/19 rears
et43
I'd say you definitely need spacers with those offsets!
If it helps/as a guide I've got 19's, here's what's fitted to my car:
Front - 8J ET20. No spacers but ideally could be brought out a bit further with 5-10mm spacers to make perfect..
Rear - 9.5J ET40 with 25mm spacers (so effectively ET15). The offset on these is just right.
As a guess, I'd say that you'd need the obligatory 20/25mm combo on your Zed, but maybe 25 on the front too? :shrug: That would give a healthy ET18 all round, but I do appreciate your wheels are slightly wider than mine.
ET43 will be lost under your arches (and might not even clear the calipers).
