LloydV Posted June 16, 2013 Share Posted June 16, 2013 (edited) Hi guys, I thought that my car was Blade silver, and i have just got an OEM spoiler to go on it, having just spent most of the afternoon on and off spraying and lacquering it, i matched it up to the car to find its a different silver.... My code under the bonnet says that the car is Blade silver (KYO) but that is whats ive used. I have since looked at this page http://www.350z-uk.c...our-code-guide/ and noticed that my car year (03 import) didn't come in Blade silver according to that table. Is it possible that the car could be Liquid Aluminium (K25) even though the vin plate says its Blade? i need to get it sorted this week really so that I can get the other bits done that I want to in time for Japfest2. Any help and opinions would be appreciated, but at the moment im looking at rubbing it back and repainting in Liquid Aluminium. You can just about see the difference in the photo but its more apparent in person. (and yes it had just started to rain when I went to get the camera) Edited June 16, 2013 by LloydV Quote Link to comment Share on other sites More sharing options...
KyleR Posted June 16, 2013 Share Posted June 16, 2013 If the plate says KYO it's KYO, so either the paint match is horrendous or your car has set in too much sun for 10 years, I'm betting crappy paint. Quote Link to comment Share on other sites More sharing options...
marzman Posted June 16, 2013 Share Posted June 16, 2013 I had some blade bits sprayed by a bodyshop, and they showed me 4 different swatches which were all KYO, and all 4 were a slightly different shade. Quote Link to comment Share on other sites More sharing options...
StevoD Posted June 16, 2013 Share Posted June 16, 2013 Hmm my import is 'blade silver' and matched to uk colours on my roof spoiler fine Quote Link to comment Share on other sites More sharing options...
LloydV Posted June 17, 2013 Author Share Posted June 17, 2013 ummmm Just found out that there are actually 7 variants of the KYO colour code...... Quote Link to comment Share on other sites More sharing options...
Wasso Posted June 17, 2013 Share Posted June 17, 2013 There may also be another application of a base coat which affects the final finish. I know Azure needs this so probably worth looking into. Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted June 17, 2013 Share Posted June 17, 2013 Just get an aerosol paint mixed up to match your car: simples. Alex. Quote Link to comment Share on other sites More sharing options...
cs2000 Posted June 17, 2013 Share Posted June 17, 2013 (edited) As alex says, much simpler. KY0 is/was used by Dacia, Infiniti, Mazda & Nissan from 2001 to the present day, Nissan still use it. It is a Master code where other paint deviate from the formula for other parts When talking about 350Z KY0 was used in the following markets on the years shown on the exterior of the metal parts of the car... 350Z AMERICAS 2004 350Z AMERICAS 2005 350Z AMERICAS 2006 350Z AUSTRALIA 2006 350Z EUROPE 2004 350Z EUROPE 2005 350Z ROADSTER AUSTRALIA 2006 350Z ROADSTER EUROPE 2004 350Z ROADSTER EUROPE 2005 K03-W2 is the code used in the engine bay on KY0 cars and KR2 is from what I can tell the colour code for the bumpers as these are plastic. All of these are applied in the factory in 2 coats. Obviously KY0 and KR2 are the same colour, its possible the different codes formulate a different base to minimise the colour difference between metal and plastic parts. Id say its just a bad paint match. Edited June 17, 2013 by cs2000 Quote Link to comment Share on other sites More sharing options...
KC350Z Posted June 17, 2013 Share Posted June 17, 2013 As alex says, much simpler. KY0 is/was used by Dacia, Infiniti, Mazda & Nissan from 2001 to the present day, Nissan still use it. It is a Master code where other paint deviate from the formula for other parts When talking about 350Z KY0 was used in the following markets on the years shown on the exterior of the metal parts of the car... 350Z AMERICAS 2004 350Z AMERICAS 2005 350Z AMERICAS 2006 350Z AUSTRALIA 2006 350Z EUROPE 2004 350Z EUROPE 2005 350Z ROADSTER AUSTRALIA 2006 350Z ROADSTER EUROPE 2004 350Z ROADSTER EUROPE 2005 K03-W2 is the code used in the engine bay on KY0 cars and KR2 is from what I can tell the colour code for the bumpers as these are plastic. All of these are applied in the factory in 2 coats. Obviously KY0 and K03-W2 are the same colour, its possible the different codes formulate a different base to minimise the colour difference between metal and plastic parts. Id say its just a bad paint match. good imfomation Quote Link to comment Share on other sites More sharing options...
LloydV Posted June 17, 2013 Author Share Posted June 17, 2013 So where around the Cambridge area can i get a nicely matched aerosol? Anyone got any recommendations? I have found one in Milton Keynes, but that is a bit of a journey just for a can of spray paint! Quote Link to comment Share on other sites More sharing options...
ChrisB Posted June 17, 2013 Share Posted June 17, 2013 Not Cambridge, but RT Performance did a fine job via their paint matching partners (who used a digital scanner) when spraying my KY0 wing 18 months ago. The digital process tests and mixes to within 3% and works well on blade silver. Allied with a good spray technician and the results were spot on. Quote Link to comment Share on other sites More sharing options...
r37 Posted July 3, 2013 Share Posted July 3, 2013 an unfortunate side effect of silver it that its very difficult to match. You'll never get an decent match from a pre-mix rattle can. Might be easier to get a bodyshop to spray it up for you or get some custom matched paint mixed. Quote Link to comment Share on other sites More sharing options...
